Thread: Exclamation Mark next to cruise control
  1. Exclamation Mark next to cruise control
    Mar 2021
    Birmingham
    Hi all
    I have a bit of a situation with my VW Passat 2008 TDI Highline. I had the clutch pedal and cylinder replaced and now there is an exclamation mark next to my cruise control symbol and it has stopped working. The mechanic is addament that its nothing to do with the work he has done as what he did, had nothing to do with cruise control.
    I have a parking brake error as well, from before, as the rear calliper's position needs to be calibrated correctly BUT cruise control still worked fine while this error was present.
    I've been told to simply check if the fuse is gone first before diving any deeper into the problem but I have checked the fuse box on the drivers side and no fuse relates to the cruise control, apparently there's a fuse box that's suppose to be in the passenger side but when i opened the cover, no fuse box was present.
    Does anyone know where I can find the cruise control fuse? I want to check that it is ok or if it needs replacing.
    any help is highly appreciated.
    Thank you in advance
  2. Re: Exclamation Mark next to cruise control
    A, A
    On my old Octavia there was 2 different clutch switches for cruise and non cruise cars, could this be the same issue on the b6? Was this changed.
    Is the clutch switch connected?
    Do your brake lights work, has the brake switch been disrupted?
  3. Re: Exclamation Mark next to cruise control
    1837 Post(s)
    There is no fuse, you need a code read to see what is wrong.
  1. Please Help Cruise Control Exclamation Mark/Not Working and MFD Adjustments (ESSEX)
    By Joe98 in forum VCDS - Help Requests
    Last Post: 17-10-2017, 01:50 PM
  2. INtermittent exclamation mark warning on dash
    By Dan Williams in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-04-2016, 05:37 PM
  3. Newbie please help abs and exclamation mark light
    By 20vt1 in forum Archive posts
    Last Post: 07-03-2007, 01:01 AM
  4. Newbie ABS and exclamation mark light HELP PLEASE!!!
    By 20vt1 in forum Passat - Archive Topics
    Last Post: 05-03-2007, 10:01 AM
  5. flashing exclamation mark on dash
    By nik in forum 80 - 90
    Last Post: 04-11-2006, 09:08 PM
