Thread: Dash lights
  1. Question Dash lights
    Hello all. I have seen other threads about replacing bulbs behind the dash, can anyone tell me how to remove the dash to do this. I have a 1996 1.6 A4
    Many thanks
  2. Re: Dash lights
    Dec 2007
    did you ever find the info you needed, I now have 4 bulbs blown and would love to fix it.
  3. Re: Dash lights
    Hi Scamp. No, nobody has come back, I only know when I'm doing over 110mph now!
    If you find out, please let me know.
    Bilbo
  4. Re: Dash lights
    Dec 2007
    I have found some info!
    Its here; https://www.vwaudiforum.co.uk/forum/s...ash+light+bulb
    not done it as yet but it does look straightforward.
    follow the link in the message and you will find the info in pictures!!!!
  5. Re: Dash lights
    Hi Scamp, thanks for the thread. I have completed the job following these instructions, simple once you know!
    Lower and pull out the steering wheel as far as it will go, push up and out the trin,its just spring clipped, undo the two philips screws and the whole unit pulls out. On mine there were only two multi plugs, lift the coloured bar and pull out.
    Went to Audi with one of the bulbs and bought 6 at £1.09 ea. Changed all as Audi said often when a new one is put in the next weakest will blow. They are all the same amps now, as Audi have changed the spec.
    Thanks again for the lead, hope yours is now fixed too.
    Kind regards
    Bilbo
  1. Dash Lights
    By chris.fulton in forum Golf MK4 - 1999 - 2004
    Last Post: 08-11-2007, 04:05 PM
  2. dash lights
    By howez in forum Passat - Archive Topics
    Last Post: 31-03-2007, 12:48 AM
  3. golf dash lights
    By bert in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-11-2006, 08:14 PM
  4. Sharan Dash lights
    By silverdales in forum Touran - Sharan - Caravelle
    Last Post: 15-02-2006, 09:10 PM
  5. Sharan Dash lights
    By silverdales in forum Archive posts
    Last Post: 29-01-2006, 11:58 AM
