Thread: Steering rack knocking noise
  1. Steering rack knocking noise
    Aug 2007
    Hook Hampshire
    21 Post(s)
    2011 Audi A7 reg RK11 VKN. 140k miles. The symptom is play (knocking noise) in the steering rack on the offside only. Thinking it was the inner ball joint, I replaced this to subsequently find out that the play is in the rack itself. There are no other symptoms and the car drives well.
    It feels as though there is a bush inside the rack which is worn causing the rack rod to move vertically and cause the noise.
    The other consideration is whether I should sent it off for reconditioning or install perhaps a later version that may have been improved. Any help would be appreciated.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  2. Re: Steering rack knocking noise
    1840 Post(s)
    We have had a few cars on this platform with what we consider excessive rack play but the MOT man never complains.
  3. Re: Steering rack knocking noise
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thanks Crasher. I expect that the play will get worse over time. I called Shaftec but they don't recon these electric racks. Any idea what road I should take. TPS does not do an exchange and the new rack costs about £2k.
    Other racks had an adjusting nut on top of the rack to take up play but there does not seem to be a procedure for this rack.
    Finally does the new rack have to be coded.
  4. Re: Steering rack knocking noise
    1840 Post(s)
    Part number 4G2 423 055 BD and £2095.38 plus a big pile of fasteners, the only company on Tec Doc that lists it is... Shaftec! their part number FRRM1000.
  1. Knocking from the steering rack.
    By shabazmo in forum Up!
    Last Post: 24-10-2020, 12:03 PM
  2. Steering gear fault. Steering rack box knocking noise
    By cip82 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-08-2020, 06:46 AM
  3. Knocking noise when steering
    By mark- in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-11-2010, 05:01 PM
  4. Knocking noise when steering
    By Audoman in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-11-2008, 08:55 PM
  5. Knocking noise when steering
    By kevwall in forum Golf MK4 - 1999 - 2004
    Last Post: 06-04-2008, 08:24 PM
