Thread: Potential DSG issues when cold
  1. Potential DSG issues when cold
    Mar 2021
    St. Helens uk
    Good evening,
    I have got a VW Passat cc 2011 170 GT DSG with 98k on the clock.
    recently when starting the car I’ve been having issues, from cold the car starts idles and revs with no issues.
    when I put the car in drive and pull away changing through the gears from 1st - 3rd it struggles to change gear juddering this is usually around 1500-2000rmp, especially up hill it is most noticeable. Also knocking very loudly.
    once the car has been through the gears 1st-3rd once then the car runs perfectly fine and no issues what so ever until the next time the car is ran from cold.
    I have recently serviced the car at 97k and the DSG was services by VW at 75k with timing belt and water pump.
    I am thinking towards DSG / Dual mass flywheel / clutch issues as the engine idles and runs fine when the car is in park but don’t want to spend a fortune if it’s an easy fix of something that I have missed 🤞🏻
    I was wondering if anyone else has been having any issues or have come across this issue that could offer some advice?
    thanks in advance
    Ben
  2. Re: Potential DSG issues when cold
    1840 Post(s)
    Sounds like a combination of the clutch pack and DMF but normally you get a few more miles than 98K, often twice that
  1. Question BUL to BGB Engine Swap - Potential Issues?
    By BenBA4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-10-2015, 07:30 PM
  2. Question 2.0 TDI Potential Flywheel Issues
    By JamieScott in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-04-2015, 11:51 AM
  3. Advice please: 2.0PD Potential issues
    By dividedby13 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-04-2014, 08:37 PM
  4. 1.9, 2.0, 3.0 Tdi and potential for DPF issues
    By Pbro in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-11-2012, 09:33 PM
  5. Potential Insurance issues
    By darich in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-04-2010, 12:05 PM
