Thread: Bonnet issue
  1. Bonnet issue
    Jun 2006
    6 Post(s)
    The bonnet pops open the first inch when pulling the cable actuated release lever but when I pull the black T shaped lever from under the bonnet it won't release. Can anyone point me in the right direction?. Do I take it the cable has stretched and isn't pulling enough to release the catch?.
  2. Re: Bonnet issue
    Jun 2006
    6 Post(s)
    Quote Originally Posted by Eugheugh View Post
    . Released it by sliding a very large screwdriver left to right between the bonnet and the top of the slam panel; If you lift the bonnet as far as it will go (about an inch) you will see the black hook that holds the bonnet down - get the screwdriver to nudge the hook left to right and have another pull on the T handle. It should release. Afterwards I used some oil to free up the mechanism. Hope this helps someone.
  1. Under Bonnet PainT issue
    By markmck in forum Passat CC
    Last Post: 15-09-2018, 12:18 AM
  2. Bonnet catch issue
    By PhilH1982 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-03-2014, 11:13 PM
  3. Replies: 0
    Last Post: 08-01-2012, 09:05 PM
  4. Snapped bonnet cable - how do I open the bonnet to replace it?
    By golfdti in forum Golf MK3 - 1993 - 1999
    Last Post: 20-04-2009, 08:12 PM
  5. Bonnet catch sensor thinks bonnet open when it isn't
    By paddtg63 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-03-2009, 08:06 PM
