Thread: Spill Pipe come off
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. Spill Pipe come off
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    So my 2012 3.0 BiTDi died tonight on the m40, started to stutter glowplug light then engine check light, then engine seemed to turn off, pulled onto the hard shoulder and tried to restart, nothing so i got out popped the bonnet to be greeted by diesel smell so had a look around and noticed diesel spill pipe had come off, the pipe had pushed off the t piece, i pushed it back on, car restarted but sounds like an injector seal or manifold gasket has gone now as have a tic tic noise, got about 10 miles and pipe came off again, are there supposed to be clips holding the pipe to the plastic? Is this a common issue as a few other joins look to be wet on the spill pipe too
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  2. Re: Spill Pipe come off
    135 Post(s)
    2026 Post(s)
    After the check valve into the banjo fitting there should be an "ear crimp clamp" N 102 313 01 which is £1.21 and on the return line side a reusable spring band clamp 4B0 422 379 which is £1.13.
  3. Re: Spill Pipe come off
    Dec 2007
    44 Post(s)
    This is driver side front injector, as the spill pipe comes to the 1st injector it keeps popping off the T peace on top of the injector, but it is weeping on several other joints too.
  4. Re: Spill Pipe come off
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    It sounds like there is excessive pressure building up in the spill pipes causing them to weep, & eventually blowing off the weakest one.
    I think they go through a non-return valve & back to the fuel return pipe.
    Check for a blockage or perhaps a faulty non return valve.
    1 1 0
  5. Re: Spill Pipe come off
    135 Post(s)
    2026 Post(s)
    That’s what I was thinking
  6. Re: Spill Pipe come off
    Dec 2007
    44 Post(s)
    I have ordered a new spill pipe it comes as both sides and goes to a return valve then into a single pipe. Also going to change the injection seals and the bolts that hold the injectors in.
  7. Re: Spill Pipe come off
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    If you're removing the injectors, perhaps worth getting them tested.
    One or more might be leaking excessive fuel back to the return pipes exacerbating the situation.
  8. Re: Spill Pipe come off
    Dec 2007
    44 Post(s)
    This car is a money pit lol . Can the rebuild these injectors? Or are they piezo like the C6 where rebuilds were not advised?
  9. Re: Spill Pipe come off
    135 Post(s)
    2026 Post(s)
    Assuming it is a CGQB engine, they have been revised and VAG don't do an exchange which probably means it isn't economical, the new part number is 059 130 277 EL and £660.31 each retail inc VAT. Bosch offer them new under their part number 0 445 117 028. A common failure is the compression blowing by and even disintegration of the fire ring, this is often shown by this
    If the injector bodies are covered in carbon when they come out, the fire rings need to be checked to make sure they are intact (or you have to find the bits) and the bores must be immaculately cleaned using solvent, compressed air and VAG cleaning kit VAS6811, I quote "Ensure cleanliness, as even minute dirt or soot particles in the copper seal area can cause another leak"
  10. Re: Spill Pipe come off
    Dec 2007
    44 Post(s)
    Yeah it is blowing by the injector, started if from cold with the bonnet up and got a blueish haze round the front injector drivers side.
  1. Milk Spill :( How to remove back seat?
    By John Rotaru in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 15-01-2017, 09:28 AM
  2. Replies: 0
    Last Post: 04-03-2014, 01:49 PM
  3. Wanted Result of oil spill on narrow road
    By Doctle Odd in forum Chat - Completely Off Topic
    Last Post: 05-11-2013, 05:47 PM
  4. Sharan Spill Off Pipe Replacement
    By bedbug in forum Touran - Sharan - Caravelle
    Last Post: 05-03-2010, 08:07 AM
  5. Diesel fuel spill pipes
    By mikeybutch in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-02-2010, 08:49 PM
