Thread: Injector Overhaul - Adaptation
  1. Injector Overhaul - Adaptation
    Feb 2007
    Hampshire
    I have had all my injectors overhauled due to an intermittent misfire (Sticky injector - Mechanical), they are my injectors and I plan to put them back into the original place.
    They have been reconditioned with new nozzles etc. by a very good company and are in spec.
    What I cannot remember is do they need to be re-adapted if they go back into the correct cylinder.
    2008 VW Passat 2.0 TDI CBAB Engine
    Many Thanks,
    Sonic.
  2. Re: Injector Overhaul - Adaptation
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    They shouldn't need to be if the numbers are already present in the ECU and they are going to be in the same cylinder as before (unlike PD injectors which can go anywhere and need no assignment). Unless the car 'forgets' of course which can happen on odd occasions. Other things like valve timing would need to be set as optimally as possible however. Some procedures / monitoring may need VCDS or similar software diagnostics to help your engine perform at its best.
  3. Re: Injector Overhaul - Adaptation
    Feb 2007
    Hampshire
    Put them back into their original place, fired up and ran no problem. No other things required doing apart from using VCDS to bleed system after filter change.
  1. Please Help Trouble code 00561 - Mixture Adaptation: Adaptation Limit (Add) Exceeded
    By FrenchAudi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-04-2018, 12:43 PM
  2. Suspension Overhaul
    By Peter_HMR in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-09-2011, 12:08 AM
  3. MK3 TD 1.9 AAZ Gearbox Overhaul Kit
    By tsam19 in forum Golf MK3 - 1993 - 1999
    Last Post: 25-05-2009, 06:21 PM
  4. Question Top Overhaul
    By ron_dave in forum Golf MK2 - 1984 - 1992
    Last Post: 08-02-2009, 11:41 PM
  5. Turbo overhaul
    By jamesmc1 in forum Passat - Archive Topics
    Last Post: 04-01-2007, 08:41 PM
