Thread: 2007 1.6 L petrol BSE engine won't start sometimes
  1. 2007 1.6 L petrol BSE engine won't start sometimes
    Mar 2021
    Limerick, Ireland
    Hello,
    I've a 2007 1.6 L patrol Passat (engine code: BSE) that won't start from time to time.
    I sat into it on a Thursday and tried to start it several times. It cranked but would not start. On one attempt, I had my foot on the accelerator, it appeared to start, immediately reved up to about 4 or 5k/min, and then dropped off to nothing. The next time I tried, it was back to cranking but not starting (with my foot on the accelerator and without).
    I sat into it two days later and it started, no problem. I took it for a spin to make sure the battery was fully charged after all my attempts to start it two days prior. Parked it back where it was and turned it off.
    I sat into it a day later and it was back to not starting.... any thoughts?
    I plugged in a code reader and there were no codes found.
    It has half a tank of petrol and the oil was changed about 2 months ago.
  2. Re: 2007 1.6 L petrol BSE engine won't start sometimes
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by Jettautofhere View Post
    Hello,
    Any old code reader might not do as VAG cars require specific VAG diagnostics to be able to retrieve the details of faults which are not stored in the generic ODB way. VCDS is the main tool used by many DIYers but other handheld more affordable (sub £200) scan tools are available such as the Autel range or with mobile phone connectivity such as Carly, and many, many others now.
    Could be a failing lift pump in the fuel tank which is common for cars of that sort of year with average to higher mileages.
  1. Question Audi A4 2.0l petrol 2007 Sline - VVT location in the engine
    By KR656 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-10-2017, 03:14 PM
  2. A6 c6 2.4 bdw engine 2007 car wont start urgent pls
    By Adel75 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-09-2017, 03:08 PM
  3. Audi A4 B6 (ALT 2.0 Petrol Engine) Rattle on cold start
    By cmulindwa in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-02-2016, 01:44 PM
  4. Changed key fob battery on 2007 A6, engine won't start
    By stack325 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-05-2013, 06:48 AM
  5. Replies: 3
    Last Post: 10-05-2012, 04:14 AM
