Thread: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
  1. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #31
    Sep 2012
    Manchester
    It’s a CRLB.
  2. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #32
    1841 Post(s)
    And still no relevant fault codes, just white smoke as per the original engine?
  3. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #33
    Sep 2012
    Manchester
    New engine doesn’t smoke like the old one and drives fine whereas the original engine did give off white smoke and was jerky.
    Other than the above it starts and sounds exactly like the original engine did which leaves us with very little else to check?
    No fault codes on the engine side other than the ACC using VCDS.
  4. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #34
    1841 Post(s)
    But poor starting? You need to do a cranking RPM test, immobilise the engine by removing the ECU relay and crank it over whilst watching the RPM in Measuring Blocks.
  5. Re: 2016 Audi A3 1.6tdi CRKB
    #35
    Sep 2022
    Surrey
    Hi everyone, newbie here.
    I’m aware this is a fairly old thread but it relates to the hpfp which I’m in need of some advice with.
    I noticed a wiff of diesel, popped the bonnet and noticed fuel leaking from the inlet metering valve on top of the hpfp. It seems to be dripping from the connector.
    I know Audi don’t sell the inlet valve separately,
    However Delphi sell the part which I ordered and fitted following the instructions… still leaking.
    No fault codes, car drives fine. No shavings on old imv mesh filter, no fillings in fuel filter, fuel filter changed every year and followed priming process, started straight away, oil changed every 5k miles.
    I’m a bit stumped… any help would be grateful.
  6. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #36
    Jul 2007
    What was the outcome was your problem fixed?
  1. P0087 Problem Fixed
    By Hamta in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 11-04-2018, 09:34 PM
  2. Bodywork specialists in Manchester
    By shahid1973 in forum Bora - 1998 - 2005
    Last Post: 22-09-2009, 12:09 PM
  3. Please Help fueling problem ?
    By vinyard87 in forum Golf MK1 - 1974 -1984
    Last Post: 22-01-2009, 11:59 AM
  4. Please Help GTTDI 115 Fueling problem
    By davey_boy in forum Golf MK4 - 1999 - 2004
    Last Post: 08-09-2008, 03:25 PM
  5. VW Specialists in Manchester!
    By y2mash in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-09-2007, 01:10 PM
