Thread: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
  1. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #21
    1836 Post(s)
    Yes, with a mirror.
  2. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #22
    Sep 2012
    Manchester
    Popped to the garage quickly after work to have a look but definitely could not see the casting numbers on the back without having to take bits off.
  3. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #23
    1836 Post(s)
    Without that number I am stuck.
  4. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #24
    Feb 2020
    Bradford
    40 Post(s)
    Try phone camera with torch on, it might just work
  5. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #25
    Sep 2012
    Manchester
    Tried with a phone and mirror. Looks like there is a heat shield bolted over that area too? Do bits actually need to be removed?
  6. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #26
    1836 Post(s)
    Not on the ones I have checked
  7. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #27
    Sep 2012
    Manchester
    Quick Update on this:
    New engine fitted with complete ancillaries from a known good car which i saw running before being removed. Only thing swapped over was my flywheel and engine wiring loom from my old engine as the new engine came from a manual and mine is DSG.
    Car is still taking 6-7 secs turning over before it will start , also drives fine and normally with no smoke etc but engine still sounds rough on idle like its still being starved of fuel? Really getting tired of it all now. No engine fault codes showing other than a couple of databus codes for the ACC. It is pretty much exactly the same as the original engine was to be honest so believe i can rule out anything engine related.
    Car has already had a new pump in the tank and fuel pump control module. Thinking about replacing the 2 fuel lines under the car now just to rule them out as that is the only thing left that hasnt been done. If no luck there, do i move onto the electronics side? ECU?
  8. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #28
    1836 Post(s)
    Check the lines on the fuel delivery unit are the corcet way around, black is feed, blue is return. The top of the sender is marked.
  9. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #29
    Sep 2012
    Manchester
    Checked the lines again and they are definately the correct way round.
    Also can now finally confirm the casting number on the back of the head you requested is V120. Alot easier now the engine is out.
    Could a worn flywheel cause these symptoms?
  10. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #30
    1836 Post(s)
    All castings up to and including 230 have the potential for internal leakage problems, is this a CUNA engine?
  1. P0087 Problem Fixed
    By Hamta in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 11-04-2018, 09:34 PM
  2. Bodywork specialists in Manchester
    By shahid1973 in forum Bora - 1998 - 2005
    Last Post: 22-09-2009, 12:09 PM
  3. Please Help fueling problem ?
    By vinyard87 in forum Golf MK1 - 1974 -1984
    Last Post: 22-01-2009, 11:59 AM
  4. Please Help GTTDI 115 Fueling problem
    By davey_boy in forum Golf MK4 - 1999 - 2004
    Last Post: 08-09-2008, 03:25 PM
  5. VW Specialists in Manchester!
    By y2mash in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-09-2007, 01:10 PM
