Thread: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
Results 11 to 20 of 36
  1. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    Sep 2012
    Manchester
    Thank you for checking Crasher.
    Any other ideas on what else to check?
    0 0 1
  2. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    Sep 2012
    Manchester
    Image below of some figures i have just taken from VCDS with the car running, mean anything to anyone?
  3. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    1840 Post(s)
    At a glance they look OK.
  4. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    Sep 2012
    Manchester
    Quick update with this:
    It seems as though i didnt realise all along that after the garage initially fitted a replacement HPFP and erased the codes, the P0087 low fuel pressure code has not returned. If the low fuel pressure was a problem, would you expect this code to return after the engine has been running?
    A new VCDS scan shows no engine faults but the car struggles to start, easy start helps it initially and it is much better when warm but still takes a while before it starts. Once started and running the engine almost sounds normal but it has a frequent tendency to just cut out randomly and more so when cold. Sometimes when idling the glow plug light will flash and the revs will hunt up and down slightly before settling again. Also in limp mode.
    Not sure if this could suggest a different problem? Could it be EGR related, not sure if this is a problem on the MK7's.
  5. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    1840 Post(s)
    If the glow plug light flashes, it has stored a code. The EGR unit on the Golf 7 so far is OK.
  6. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    Sep 2012
    Manchester
    Hi Guys,
    As a follow up to this, a local garage today has had a look at the car. Car was driven and is blowing out white smoke, more so when warmed up. Drives ok but occasionally is jerky with some sort of misfire.
    Garage initially thought it may be an injector but had a look and dont think it is after checking. They have found that all 4 glow plugs have diesel in them which bubbles and increases when the car warms up. They believe it is likely to mean the head has a crack and my options are to either have the head taken off and sent to an machinist to be checked and repaired if possible or id be better of sourcing a known good used engine to replace.
    Anyone experienced the leaking fuel at the glow plugs before?
  7. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #17
    1840 Post(s)
    Get them to look at the back of the head for this casting number
  8. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #18
    Sep 2012
    Manchester
    Hi Crasher, any particular reason why?
  9. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #19
    1840 Post(s)
    Humour me...
  10. Re: 2015 golf 2.0 gt tdi fueling problem - p0087 - please help - any specialists in manchester?
    #20
    Sep 2012
    Manchester
    Is it possible to see those castings numbers with the engine and turbo still fitted?
  1. P0087 Problem Fixed
    By Hamta in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 11-04-2018, 09:34 PM
  2. Bodywork specialists in Manchester
    By shahid1973 in forum Bora - 1998 - 2005
    Last Post: 22-09-2009, 12:09 PM
  3. Please Help fueling problem ?
    By vinyard87 in forum Golf MK1 - 1974 -1984
    Last Post: 22-01-2009, 11:59 AM
  4. Please Help GTTDI 115 Fueling problem
    By davey_boy in forum Golf MK4 - 1999 - 2004
    Last Post: 08-09-2008, 03:25 PM
  5. VW Specialists in Manchester!
    By y2mash in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-09-2007, 01:10 PM
