Thread: How do you perform a DPF regeneration on a CFFB engine?
  1. How do you perform a DPF regeneration on a CFFB engine?
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Please find an autoscan below:
    Code:
    Monday,01,March,2021,17:18:51:33544VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 20.12.0.1 (x64)
    Data version: 20201125 DS322.1
    www.Ross-Tech.com
    VIN: WVGZZZ5NZEW034174   License Plate:
    Chassis Type: 5N-VW36 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 4C 52 53
              56 61 62 72
    VIN: WVGZZZ5NZEW034174   Mileage: 59170km-36766miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    22-AWD -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    4C-Tire Pressure II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    Address 01: Engine (J623-CFFB)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 FQ    HW: 03L 907 309 AE
       Component: R4 2.0l TDI   H28 9977
       Revision: 41H28---    Serial number: 00000000000000
       Coding: 00250032042701080000
       Shop #: WSC 40235 001 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018FQ 003013
       ROD: EV_ECM20TDI01103L906018FQ_VW36.rod
       VCID: 7EF79375E1747D7470-802A
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
       Part No SW: 0BH 300 012 A    HW: 0BH 927 711 C
       Component: DSG DQ500-7A  H08 2236
       Revision: 00H08V01
       Coding: 0014
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_TCMDQ500021 001001
       ROD: EV_TCMDQ500021_001_VW36.rod
       VCID: 214D8809304AE28C2D-8074
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 BD    HW: 5N0 614 109 BD
       Component: J104   C6 450M VDF2 0011
       Revision: --H07---    Serial number: 00000007388892
       Coding: 0056641
       Shop #: WSC 01357 011 00200
       VCID: 6ED7A33579140DF4E0-803A
    Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
       Part No SW: 5K0 907 044 GJ    HW: 5K0 907 044 GJ
       Component: Climatronic   H19 1313
       Revision: 00001004
       Coding: 0010004003
       ASAM Dataset: EV_Climatronic A01010
       ROD: EV_ClimaAutoBasis_VW36.rod
       VCID: 79FD8069F85A5A4C45-802C
    5 Faults Found:
    9473137 - Motor for Left Temperature Flap
              B108C 71 [008] - Actuator stuck
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 27
                        Mileage: 59155 km
                        Date: 2021.02.23
                        Time: 12:16:07
    9473393 - Motor for Right Temperature Flap
              B108D 71 [008] - Actuator stuck
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 27
                        Mileage: 59155 km
                        Date: 2021.02.23
                        Time: 12:16:08
    9474161 - Motor for Defroster Flap
              B1090 71 [008] - Actuator stuck
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 4
                        Reset counter: 27
                        Mileage: 57824 km
                        Date: 2020.10.15
                        Time: 14:42:57
    9474417 - Motor for Front Air Distribution Flap
              B1091 71 [008] - Actuator stuck
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 4
                        Reset counter: 27
                        Mileage: 58404 km
                        Date: 2020.12.10
                        Time: 17:11:59
    9472881 - Motor for Fresh Air / Recirculated Air Flap
              B108B 71 [008] - Actuator stuck
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 24
                        Mileage: 58719 km
                        Date: 2021.01.26
                        Time: 07:15:19
    Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
       Part No SW: 5K0 937 086 Q    HW: 5K0 937 086 Q
       Component: BCM PQ35 M    122 0173
       Revision: BC122001
       Coding: 48180A3B8025F1C0408800C0340081644BD1AA88436D81206480C7000041
       VCID: 428F2785DD0CD99454-8016
       Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
       Component: Wischer 04091  013 0204
       Serial number: N2955119   °204!
       Coding: 009795
       Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
       Component: RLS 030913 05  54  0403
       Coding: 02304D
       Subsystem 3 - Part No: 1K8 951 171
       Component: DWA-Sensor 00  001 0104
       Coding: 000000
       Subsystem 4 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Coding: 000000
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
                002 - Lower Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 27
                        Mileage: 59178 km
                        Time Indication: 0
                        Date: 2015.07.23
                        Time: 17:17:32
                 Freeze Frame:
                            Term 15 On
                        Voltage: 10.35 V
                            ON
                            ON
                            ON
                            OFF
                            OFF
    Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
       Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0025
       Revision: --------    Serial number: 56231324601942
       Coding: 149303
       ASAM Dataset: EV_EPHVA2C000000000 002008
       ROD: EV_EPHVA2C000000000.rod
       VCID: 4483219DCF18D7A466-8010
    Address 15: Airbags        Labels: 5N0-959-655.lbl
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__20E VW10 HI   2118
       Revision: 26019000    Serial number: 003L7PJENPDL
       Coding: 0012357
       VCID: 7CF3997D3F686F645E-8028
       Subsystem 1 - Serial number: 6332MTS612992393
       Subsystem 2 - Serial number: 6342MTS664362383
       Subsystem 3 - Serial number: 6351HTS61HJG7CKR
       Subsystem 4 - Serial number: 6361HTS6KAMG7CKJ
       Subsystem 5 - Serial number: 00000000000000000
       Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
       Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
       Component: LENKS.MODUL   016 0140
       Revision: FF010042    Serial number: 20130902100926
       Coding: 1882140000
       ASAM Dataset: EV_SMLSNGVOLWSXS A01004
       ROD: EV_SMLSNGVOLWS.rod
       Multifunction steering wheel control module:
       Subsystem 1 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H31 0037
       Coding: 820000
    Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
       Part No SW: 5N0 920 983 D    HW: 5N0 920 983 D
       Component: KOMBI         H04 0611
       Coding: 411F01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
       VCID: 36674B5589C47534E8-8062
    Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
       Part No SW: 7N0 907 530 AL    HW: 7N0 907 530 AL
       Component: J533  Gateway H58 1642
       Revision:   H58       Serial number: 030913F2000670
       Coding: 356003
       VCID: 7AFF9F65F55C51544C-802E
    Address 22: AWD        Labels: 0AY-907-554-V1.clb
       Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
       Component: Haldex 4Motion      0043
       Coding: 0000005
       VCID: 4D9504B9D45216ECB9-8018
    Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
       Part No SW: 5K0 953 234     HW: 5K0 953 234
       Component: IMMO          H04 0611
       Coding: 000000
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
       ROD: EV_Immo_UDS_VDD_RM09_VW23.rod
       VCID: 6ADFAF258DFCE1D4BC-803E
    Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
       Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
       Component: SG EXT.PLAYER H19 0770
       Revision: A1001003    Serial number: 7665193495
       Coding: 020100
       VCID: 2B516A214A8638DC87-807E
    Address 37: Navigation (J794)       Labels:| 1K0-035-27x-37.clb
       Part No SW: 3C8 035 279 M    HW: 3C8 035 279 M
       Component: RNS315-EU   H73 0407
       Serial number: VWZAZ2N0470632
       Coding: 0400040104000C0000009002
       ASAM Dataset: EV_RNS315EUV2UDS 001705
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 35654C5994C27E2CE1-8060
       Data carrier:
       Subsystem 1 - Part No: 3AA 919 866
       Component: EUR_W_V4  0050
    Address 42: Door Elect, Driver (J386)       Labels:| 3C0-959-70X-GEN4.clb
       Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0504
       Revision: 13110009    Serial number: 0007362974
       Coding: 0202B4
       ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
       ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
       VCID: 387B456D83D08344FA-806C
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  009 1504
       Serial number: 00000008176006
       Coding: 000090
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 5N0 909 144 R
       Component: EPS_ZFLS Kl. 203    3501
       Revision: 00H22000
       Shop #: WSC 01324 785 00200
       VCID: 408B2D8D1300CB8442-8014
    Address 52: Door Elect, Pass. (J387)       Labels:| 3C0-959-70X-GEN4.clb
       Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0504
       Revision: 15110009    Serial number: 0007351749
       Coding: 0202B4
       ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
       ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
       VCID: 397D4069B8DA9A4C05-806C
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  009 1504
       Serial number: 00000008182363
       Coding: 000090
    Address 53: Parking Brake        Labels: 3AA-907-801.clb
       Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
       Component: J540 EPB4  VW-86594 0010
       Revision:   H19       Serial number: 00000001365377
       Coding: 0026167
       VCID: 36674B5541C47534E8-8062
    Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
       Component: Batt.regelung H58 1642
       Coding: 030F1859
       VCID: 71EDB849A82A120CFD-8024
       Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0180
       Serial number: 30232C31191491927187
    End-------------------------(Elapsed Time: 03:24)--------------------------
    Looking for some help on how to regenerate the DPF on a CFFB engine?
    I think the protocol is UDS, not CAN.....
    I've seen this page on Ross Tech but trying to work out which one is mine.....(thinking it might be 1.6l/2.0l R4 & 3.0l V6 CR-TDI (UDS) - the last one at bottom of the page on this link http://wiki.ross-
    tech.com/wiki/index.php/Diesel_Particle_Filter_Emergency_Regeneration
    Reason for wanting to perform a regeneration is due to DPF light being on.....
    Any help would be appreciated.
  2. Re: How do you perform a DPF regeneration on a CFFB engine?
    Jul 2018
    8 Post(s)
    Think it's pretty obvious now after seeing this.....
  3. Re: How do you perform a DPF regeneration on a CFFB engine?
    Aberdeen
    63 Post(s)
    What is the soot loading? or particle filter load.
  4. Re: How do you perform a DPF regeneration on a CFFB engine?
    131 Post(s)
    1974 Post(s)
    You go into login and the code should pop up. There will be one for adaptation and one for basic setting. Have a look in the menu for those and you should see regeneration whilst driving and regeneration whilst standing, can't remember which way around. Then you enter 1 in the box and press OK and the forced regen process can start. Ideally you want to be doing 3k ish RPM on a long straight run... something not that easy in town.
  5. Re: How do you perform a DPF regeneration on a CFFB engine?
    Jul 2018
    8 Post(s)
    Hi @Scott K and @Crasher the vehicle is UDS so I was struggling to find all the correct values.....used to CAN and using the MVBs / measuring blocks.....
    I shall have to search through the advanced measuring values to find the ones I need to get those values....
    I think I did find soot loading or particle filter load yesterday and was between 12.0-13.0g (grams?)
    Let me report back with a screenshot of the values.
    But I am starting to think that there is no DPF issue......there are no logged fault codes for it the Engine module....or throughout the rest of the vehicle....only picks up on a few on HVAC (actuator stuck) and CENT ELC (see
    scan above).
    I am starting to suspect that there is some moisture in the cluster and maybe perhaps weak / poor solder joints that are causing current leakage and causing some lights on dash / cluster to illuminate for no reason.
    Going to remove it and see if keeping inside overnight will dry it out and solve the problem.
  1. P0183 G81 FTS problem on a CFFB 2.0Tdi engine
    By shabazmo in forum Golf MK6 - 2009 - 2013
    Last Post: 26-11-2020, 11:33 AM
  2. Question 2011 Passat 2.0 TDI CFFB Engine - can you use VCDS to lock shut EGR valve
    By drjohnbullas in forum VCDS - General Questions
    Last Post: 18-06-2019, 08:30 PM
  3. Do I need to perform re-learn proceedure after changing Air Control Flap?
    By OiledBalls in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 19-02-2013, 10:13 PM
  4. Replies: 1
    Last Post: 27-02-2012, 11:13 AM
  5. Please Help How should a tdi engine perform
    By KevinR in forum Polo - Derby - Lupo - Fox
    Last Post: 29-04-2009, 08:36 PM
