Thread: info re flat bottom steering wheel and air bag suitability.
  1. info re flat bottom steering wheel and air bag suitability.
    Oct 2015
    Banbridge
    10 Post(s)
    Hi folks I need a bit of advice if possible, i have purchased a genuine flat bottom steering wheel for my 2015 A6 Avant ultra 2.0 tdi, it was cheap as it came with no airbag and I knew I would need a different airbag as mine would not fit as the connections that secure the airbag to the steering wheel are different so if I get another air bag with the correct fitting would this just be plug and play as the electrical connections are the same or will the car throw up warning lights etc.
    thanks kevin.
  2. Re: info re flat bottom steering wheel and air bag suitability.
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    If you remove yours with the battery disconnected and refit the new one then reconnect the battery you shouldn’t get any airbag lights unless something is faulty.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: info re flat bottom steering wheel and air bag suitability.
    Oct 2015
    Banbridge
    10 Post(s)
    cheers dean I appreciate it.
  1. Flat bottom steering wheel upgrade
    By Leemacca83 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 28-01-2021, 10:12 AM
  2. Flat bottom steering wheel fitting?
    By Baz_doc in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 15-12-2018, 08:40 PM
  3. A4 facelift flat bottom steering wheel with TT flat bottom airbag?
    By hsmithboy30 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-11-2014, 12:34 AM
  4. RS style flat bottom steering wheel
    By _Tazman_ in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-09-2013, 04:02 PM
  5. Question Flat bottom steering wheel
    By size12 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-08-2013, 09:14 AM
