Thread: VCDS Code 4891 - EGR Valve
  1. VCDS Code 4891 - EGR Valve
    Jun 2010
    Ireland
    Just got the below code. Anyone any ideas?
    1 Fault Found:4891 - EGR Valve (N18)
    P0403 00 [040] - Malfunction
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 67
    Mileage: 217885 km
    Date: 2020.11.27
    Time: 12:37:24
    Engine speed: 1608.50 /min
    Normed load value: 23.5 %
    Vehicle speed: 88 km/h
    Coolant temperature: 85 °C
    Intake air temperature: 11 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 14.720 V
    Unlearning counter according OBD: 40
    Air mass: actual value (mg/stroke): 656.3 mg/stroke
    EGR Vacuum Regulator Solen.val.: activation: 15.00 %
    EGR Solen.val.: actual value: 96.61 %
    EGR valve: offset closed: 0.23 %
    Actuator for high pressure EGR: status-Bits 0-7: 0
    for high pressure EGR: status-Bits 0-7: 55
    Actuator for high pressure EGR: status-Bits 0-7: 3
    High press EGR actuator: actual unconditioned volt val: 1094.8 mV
  2. Re: VCDS Code 4891 - EGR Valve
    1836 Post(s)
    What is the vehicle and engine?
  3. Re: VCDS Code 4891 - EGR Valve
    Jun 2010
    Ireland
    2011 VW Sharan 2.0TDI CFFB 140bhp
  4. Re: VCDS Code 4891 - EGR Valve
    1836 Post(s)
    Normally failure of the EGR cooler unit on the back of the engine.
  5. Re: VCDS Code 4891 - EGR Valve
    Jun 2010
    Ireland
    Thanks Crasher.
    Is this a mechanical failure what is the recommended test or fix?
  6. Re: VCDS Code 4891 - EGR Valve
    1836 Post(s)
    It gets clogged up which makes the motor fail so has to be replaced. DO NOT be tempted to fit anything other than a genuine part from VW, pattern ones are a disaster.
  1. Throttle valve adaption - no option in vcds?????
    By d3927 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 30-07-2020, 11:30 AM
  2. Please Help ESP and limp mode when cold, VCDS says hpfp valve n276
    By corino in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-01-2015, 01:54 PM
  3. Replies: 0
    Last Post: 03-12-2013, 11:51 PM
  4. Please Help 2010 A3 2.0TDI - EGR Fault - 4891/4892 - P0403
    By jamrolu in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-07-2013, 10:17 AM
  5. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
