Thread: Water leak in boot
  1. Water leak in boot
    Jun 2019
    Finistère, France
    Hi guys,
    Here for some help. Searched around but nothing has seemed to work so far.
    I have a 2011 Audi a3 2.0 sportback s-line with the panoramic sunroof (if this is the possible issue).
    The other day I went into the boot and could smell damp, lifted the carpet to the spare location and beholds, I have a nice pool in the boot. I have searched on the forums on possible locations and have not had any luck.
    So far I have removed, checked the tail light seals, fuel cap location, rear washer, boot seal, removed rear bumper and checked the one way flaps that let air out when closing doors. <- BTW these flaps had a huge puddle behind each one, yet they seem fine, very tight fit and funtion the way they should and show no sign of water leaking through there.
    Back seats, carpet, ceiling, pillars are all bone dry.
    Is it possible a sunroof drain could be at fault? Anybody else have this issue before?
    Thank you in advance for your feedback
  2. Re: Water leak in boot
    1837 Post(s)
    The words “panoramic sunroof” and “water ingress” have been known to make a grown mechanic cry.
  3. Re: Water leak in boot
    Jun 2019
    Finistère, France
    yep, I bet.... Been searching with no luck. Im close to ripping the headliner out at this point
  4. Re: Water leak in boot
    Southampton, UK.
    I had a wet boot and found it to be a degraded seal around the top brake light, only spotted after I removed all plastic trim and sat in the boot whilst a hose was run over the back of the car.
    2003 VW Golf Est 1.9 TDI 130
    2006 Audi A3 2.0 TDI Sport 140
  5. Re: Water leak in boot
    Jun 2019
    Finistère, France
    Thank you for your feedback, i'll have another check. Will probably strip the rear out and run water over it like you did
  6. Re: Water leak in boot
    Jun 2019
    Finistère, France
    Hello all, finally found the culprit....
    The old owner thought it would be a great idea to run a reverse camera video cable behind the boot seal. He has bent the seal all over the place and ripped it in one spot. I didnt see any of this before as from the back of the car it all seemed ok. When tugging the boot seal, thats when s**t hit the fan.
    I am going to order a new seal. Could somebody be able to confirm that this is the part number needed for my vehicle please? Want to make sure its the right one Part Number: 8P4827705E
  1. Water leak into boot
    By Karl in forum Tiguan
    Last Post: 08-08-2017, 09:10 PM
  2. Question Saloon boot leak, water inside wheel well
    By warp_speed in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-09-2011, 06:06 PM
  3. Question Polo - water leak in boot
    By T R CUmming in forum Polo - Derby - Lupo - Fox
    Last Post: 17-01-2010, 07:20 PM
  4. Help! Trunk - Boot Water Leak
    By billA6 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-12-2008, 05:36 AM
  5. Water leak in Boot
    By chris sheldon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-07-2008, 03:45 PM
