Thread: Brake fault
Results 1 to 8 of 8
  1. Brake fault
    Oct 2019
    Hertfordshire
    I've a strange fault I need to address and hoping someone has had a similar problem or a good starting point.
    I changed the wheel bearings on the rear, all discs and pads front to back, rear abs reluctor rings and front sensors
    Car has been fine for a month and now I have the yellow abs light on soild and a red flashing brake light sign in large on the dash.
    The brakes feel like the abs is kicking in ll the time
    Any help appreciated
    Audi a4 b5 1.8t sport 1999
    Sent from my CLT-L09 using Tapatalk
  2. Re: Brake fault
    Feb 2020
    Bradford
    40 Post(s)
    Ideally you need to pull the fault code from the system, otherwise a visual inspection of all four wheels and measuring the four sensors may help. Those old front sensors may yet be needed if they were working and especially if swapped for non genuine but it could be anything so a fault code is the way to go
  3. Re: Brake fault
    1840 Post(s)
    Quite clearly the ABS ECU is detecting a wheel speed signal dropping out so thinking a wheel is locking and reducing pressure to that caliper but as the ABS light is on I would expect the system to now work so first a code read is a must as even if you inadvertently rectified the fault, the warning will not clear. To help determine which wheel speed sensor is dropping out, you will need to observe each wheel speed signal whilst driving using the Measuring Block output with a diagnostic system that can display these. The only problem here is the Bosch ECU used in the cars is a right pain, when you exceed approx 20Kmh, the system drops communications and limits the ease of testing on public roads with becoming a nuisance or danger to other road users and this measurement must be done by an assistant sitting in the back seat, with the location of an 8D diagnostic plug this is easy and why I think it was placed there.
  4. Re: Brake fault
    Oct 2019
    Hertfordshire
    I done a code read using the free vds software
    And I got error comms malfunction?
    Tried a few times and just comes up the same yet it use to work giving me the issues
  5. Re: Brake fault
    Oct 2019
    Hertfordshire
    I've tried again with the ignition off and now these are my results see picture
    And with ignition on it says excessive comm errors
  6. Re: Brake fault
    1840 Post(s)
    That’s engine, not ABS and VCDS Lite is next to useless.
  7. Re: Brake fault
    Oct 2019
    Hertfordshire
    Which program do I need to work on my laptop please
  8. Re: Brake fault
    1840 Post(s)
    Full and registered VCDS, you don’t need the up to date HEX-NET cable, you should be able to find an older genuine VCDS cable on eBay where someone has moved up to a HEX-NET. Avoid illegal cables at all costs.
  1. very odd brake fault
    By Eugheugh in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-10-2013, 10:19 AM
  2. Please Help Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    By IrlA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2012, 12:56 AM
  3. Bora ABS Fault and Brake Fault
    By jonty89 in forum Bora - 1998 - 2005
    Last Post: 05-08-2008, 08:00 AM
  4. ABS/Brake Fault
    By colhowe1 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-04-2008, 05:33 PM
  5. First Brake Fault
    By Big G in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-11-2007, 09:14 AM
