Thread: Gearbox and Rear Diff Oil Good forever?
Results 1 to 10 of 12
  1. Gearbox and Rear Diff Oil Good forever?
    Dec 2008
    Manual 1.9tdi 6spd OX1 gearbox here with quattro rear diff and over 200,000 miles on the original drivetrain oils. No indication anywhere as to wether the lifetime life of the oils really is that, for as long as the car is alive. Plenty of threads where people say they've changed the oil because they thought it a good idea and some of them saying better gearchanges. I can well believe that some of this might be in peoples heads. My gearchanges are fine, Im not aware of any diff problems and wonder should I just leave it alone. No oil leaks so no need to top up. Can it be true that the oil in there will last forever? Has anyone ever put this to some sort of real objective test like measure power at wheels before and after a torsen diffs oil change?
  2. Re: Gearbox and Rear Diff Oil Good forever?
    135 Post(s)
    2033 Post(s)
    At even 50K the oil can be "worn out" and cause the diff to rumble in cornering.
  3. Re: Gearbox and Rear Diff Oil Good forever?
    May 2006
    Redruth, United Kingdom
    I have never been a fan of "fill for life". This mainly came about due to the car manufacturers making the vehicles cheaper to service. Not a propblem for the average private owner but if you are a fleet business then the difference in servicing costs make the final choice as to what manufacturer gets the business.
    Gearbox and diff oils dont have to deal with the combustion byproducts and the same kind of heat an engine oil is subjected to. But, they still get hot and they still shear down (thin) over time as the longchain molecules in the oil slowly get broken down by being munched by gear teeth etc.
    Cheers,
    Guy
  4. Re: Gearbox and Rear Diff Oil Good forever?
    135 Post(s)
    2033 Post(s)
    Shear down is a better way of describing it than wearing out.
  5. Re: Gearbox and Rear Diff Oil Good forever?
    Dec 2008
    Cheers, sounds like another job to add to my list. Must figure out quantity and specs now.
  6. Re: Gearbox and Rear Diff Oil Good forever?
    May 2006
    Quote Originally Posted by BMurr View Post
    What model/year is your A4?
    Cheers,
    Guy
  7. Re: Gearbox and Rear Diff Oil Good forever?
    May 2006
  8. Re: Gearbox and Rear Diff Oil Good forever?
    Dec 2008
    Quote Originally Posted by oilman View Post
    Cheers,
    Guy
    2004 B6 Avant 1.9TDi Quattro SE (6 speed gearbox)
  9. Re: Gearbox and Rear Diff Oil Good forever?
    May 2006
    For the rear diff, 75w-90 Meeting API GL5 and we often recommend the Fuchs Titan Sintopoid 75w-90 as it also meets the VW TL 521 45-Y spec for your car and 1.5ltr will do the change Fuchs TITAN SINTOPOID SAE 75W-90 synthetic gear oil
    For the gearbox you will need 75w-80 or 75w-90, the VAG spec for your car is G 052 911 and we have always had good results with the Fuchs Sintofluid 75w-80 Fuchs TITAN SINTOFluid SAE 75W-80 Syn Manual Gear Fluid As for capacity the 01E gearbox is 2.5ltr and the 02X is 3.5ltr.
    Cheers,
    Guy
  10. Re: Gearbox and Rear Diff Oil Good forever?
    May 2012
    Everywhere
    308 Post(s)
    Yes G 052 911 is allowed to be a 75W80 or 75W90 , but I've prefer a thinner G 052 171 , 70W75 like Fuchs Titan Sintofluid FE SAE 75W or Millers TRX Synth 75W , a common VAG spec found in A3 S3 etc .
    I've a mechanic using the Fuchs G 052 171 in a box speced for G 052911 and it aces the cold changes .
  1. A5 gearbox and diff oil change?
    By d3927 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 01-11-2015, 02:43 PM
  2. Oil changed, rear diff topped up, gearbox oil changed new tyres.....
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-11-2013, 03:00 PM
  3. A3 gearbox/diff
    By foxto in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 06-07-2012, 04:39 PM
  4. Whining diff in the gearbox?
    By m4xmw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-05-2008, 05:21 PM
  5. Help Gearbox / diff kaput?
    By Roo65 in forum Touran - Sharan - Caravelle
    Last Post: 21-04-2008, 08:30 PM
