Thread: Driver's door won't open with emergency key
Results 1 to 1 of 1
  1. Driver's door won't open with emergency key
    Jul 2011
    Was having problems for a couple of days with central locking and electric windows not working on driver's side (front and rear). Switches not illuminating either. First noticed that door was showing as open on MFD when in fact was closed.
    That came and went a couple of times, and was able to unlock driver's door with emergency key if it wouldn't open normally.
    Now even that won't work, and when I turn the key in the lock nothing happens.
    So I'm having to get into the car from the passenger side, but at least that seems to be OK. Car seems to be driving normally otherwise.
    For what it's worth I got a new battery the other day, and it wasn't coded. It is a proper spec Yuasa AGM 096 battery though, and the stopstart is working again - it hasn't for a couple of years, which I'm assuming was because the battery was in poor condition. It was almost seven years old when replaced, and was the original battery.
    2014 Passat Executive estate, 1.6 TDi, 130,000 miles
  1. Driver’s door will not open from outside
    By Rsheen in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-04-2020, 09:50 PM
  2. Driver door handle wont open door broken ....pulley rod....help !
    By Sam James in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-04-2019, 01:10 PM
  3. Cannot open driver door at all
    By Leckie in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-12-2015, 05:50 PM
  4. HELP!!! Driver door won't open.
    By dbooker89 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-05-2014, 01:21 PM
  5. Replies: 5
    Last Post: 28-04-2008, 10:34 PM
