Thread: Kessy Unit/CCM Damage Unregistring Key
  1. Exclamation Kessy Unit/CCM Damage Unregistring Key
    Feb 2021
    Sunderland, UK
    Hi Guys,
    Iv'e purchased myself a crashed damaged a6 avant, the damage is to the rear driver side quater. The key does't unlock the car and i have replaced the battery, power cut off fuse and tried holding the key to the syncronising area to no avail.
    I've been told this has caused damage to the vehicles kessy unit however i cant find anywhere online that says anything about a kessy unit however apparently the CCM is located around the area that is damaged - above the fuse box, however looking at photos of a CCM it doesn't look like anything that is shown.
    My questions are:
    Does anyone know if it's the CCM or Kessy Unit?
    Where Is this Located?
    How do i replace one of these if it's broken?
    Will the new CCM/Kessy unit need coding in?
  2. Re: Kessy Unit/CCM Damage Unregistring Key
    Mar 2012
    Ireland
    6 Post(s)
    This may help https://audi.7zap.com/en/rdw/audi+a6...blank">#11</a> one of the Kessy antenna #11 is in that area
  3. Re: Kessy Unit/CCM Damage Unregistring Key
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Its the BCM which is mounted behind the right quarter panel trim. A bit further up from the pic you took. If its damaged it will need a new one matched to the vin of the car and coded online with ODIS for it to work and your keys too. If its intact ie opened and inspected for a broken circuit board etc then check your wiring for damage and shorts before replacing it. A damaged antenna will not cause issues
  1. Help and advise please! Kessy!!
    By Phil7483 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 05-04-2020, 03:37 PM
  2. Kessy problems
    By jasst in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-05-2019, 07:23 PM
  3. Replies: 1
    Last Post: 18-11-2011, 08:13 PM
  4. Help- need to replace ccu after water damage and code in replacment unit
    By GeeCee in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-11-2011, 05:14 PM
  5. Question Changing brake pads and damage to ABS unit
    By tyberwan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-06-2009, 08:42 PM
