Thread: How I fixed my Audi A6 throttle issue with "Throttle Reset OBD2" ELM327
  1. How I fixed my Audi A6 throttle issue with "Throttle Reset OBD2" ELM327
    Feb 2021
    Budapest
    Sharing my experience !!
    I Fixed my Audi A6 Quattro 2006 throttle Issue with ELM327 "Throttle Reset
    OBD2"
    I had my car sitting in my garage more than 2 years and I jump started car
    and turned on but but car was shaking and turning off, so my friend was a
    mechanic and he diagnosed it and told me that it was throttle issue, so I had
    an old elm327 v1.5 bluetooth obd2 adapter and after searching I came upon
    this application on google play "Throttle Reset OBD2" which claims to do
    throttle adaptation and reset but still I managed to take a risk and try it on my
    AUDI and I hooked up obd2 adapter and turned ignition on pressed on clear
    codes and then reset throttle adaptation and then adaptation process , after
    process was done I turned on car and was running so smoothly. I just
    wanted to share this application with you guys maybe it might help you save
    you from paying soo much in order to fix a small issue.
    I followed this article: Need technical support and help with using Throttle Reset OBD2 application ?
    and download from Google Play : https://play.google.com/store/apps/d...et&hl=en&gl=US
  2. Re: How I fixed my Audi A6 throttle issue with "Throttle Reset OBD2" ELM327
    Oct 2020
    Florida
    Thank you for sharing this information, I am sure that it will be helpful for those that will encounter the same issue.
  3. Re: How I fixed my Audi A6 throttle issue with "Throttle Reset OBD2" ELM327
    Mar 2022
    London
    Quote Originally Posted by MrMikeR View Post
    OBD2"
    Application Developer Front-End job with you guys maybe it might help you save
    I am happy for you! Good job!
  4. Re: How I fixed my Audi A6 throttle issue with "Throttle Reset OBD2" ELM327
    Jul 2008
    Lisburn
    15 Post(s)
    Great fix I love a good cheep, sorry, efficient fix.
    thanks for sharing.
    I wonder what other apps are out there like this.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  1. Had a Turbo "fixed" (vac tube Problem" now it "surges at 2200RPM
    By andysuth in forum Touran - Sharan - Caravelle
    Last Post: 20-05-2016, 02:43 PM
  2. Replies: 7
    Last Post: 29-09-2012, 04:50 PM
  3. Off throttle "BANG" in 2nd gear (A4 1.9TDI)
    By Gwilo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-07-2012, 06:12 PM
  4. Replies: 39
    Last Post: 21-07-2012, 08:17 PM
  5. Cleaned EGR valve now car is "jumpy" in throttle response
    By conor2949 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2009, 09:42 PM
