Thread: 2008 Passat 1.9tdi Parking Brake Fault
  1. 2008 Passat 1.9tdi Parking Brake Fault
    Oct 2017
    London
    12 Post(s)
    I have a Passat here with a flashing parking brake warning light. The parking brake itself works fine. With VCDS it will accept the parking brake code and when the other faults are fixed and cleared the whole fault resets and comes back. The car has autohold and the coding I put into the parking brake is 0000057 (PR-UH2) Once this is done the faults drop to 2 faults. (This clears the incorrect vehicle type fault code as well) So I do a parking brake function test via basic settings then the faults drop to 1 so i re-adjust the g251 via the abs module (although the reading is always there when checking the MVB). With all the faults cleared the parking brake light goes off for a second before coming back on and throwing all 4 faults again. I have a feeling someones been altering the abs code or some other code before but I cant confirm this. Code below, thanks in advance for any help offered.
    [code]Thursday,18,February,2021,14:56:02:42137
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
    VCDS Version: 20.12.0.0 (x64) HEX-V2 CB: 0.4529.4
    Data version: 20201124 DS322.0
    www.Ross-Tech.com
    VIN: XXXXXXXXXXXXXXXXX License Plate:
    Chassis Type: XX (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56
    VIN: XXXXXXXXXXXXXXXXX Mileage: 236370km-146873miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-021-BLS.clb
    Part No SW: 03G 906 021 RS HW: 03G 906 021 AB
    Component: R4 1,9L EDC 000SG 1844
    Revision: --H09--- Serial number: XXXXXXXXXXXXXX
    Coding: 0000031
    Shop #: WSC 01229 210 101217
    VCID: 015E7518ED0343937CD-8054
    4 Faults Found:
    001350 - Sensor 1 for Exhaust Temp Bank 1 (G235)
    P0546 - 000 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 236375 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:36:14
    Freeze Frame:
    RPM: 798 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Temperature: 40.5°C
    Temperature: 924.0°C
    Absolute Pres.: 969.0 mbar
    005658 - Glowplug for Cylinder 1 (Q10)
    P161A - 000 - Open Circuit
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 236375 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 14:41:50
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.46 V
    Bin. Bits: 00000100
    Temperature: 2.7°C
    Bin. Bits: 00110000
    005659 - Glowplug for Cylinder 2 (Q11)
    P161B - 000 - Open Circuit
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 236375 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 14:41:50
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.46 V
    Bin. Bits: 00000100
    Temperature: 2.7°C
    Bin. Bits: 00110000
    005661 - Glowplug for Cylinder 4 (Q13)
    P161D - 000 - Open Circuit
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 236375 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 14:41:50
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.46 V
    Bin. Bits: 00000100
    Temperature: 2.7°C
    Bin. Bits: 00110000
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
    Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
    Component: J104 C4 440 V2 0011
    Revision: --025--- Serial number: 00000786066928
    Coding: 0001283
    Shop #: WSC 00028 028 00001
    VCID: 2B02F7B03F0F79C3F61-807E
    No fault code found.
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
    Component: Climatic PQ35 142 1111
    Revision: 00142031 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 76B416C4B4CD742B59F-8022
    Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
    Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
    Component: Bordnetz-SG H54 2602
    Revision: 00H54000 Serial number: 00000005964787
    Coding: 00800F0700041000470A00000F000000000859435C00010000 0000000000
    Shop #: WSC 00999 444 64523
    VCID: 323CEAD41825280BB57-8066
    Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer 170708 022 0601
    Coding: 00046997
    Shop #: WSC 00999
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
    Component: J234__006 VW10 HI 1815
    Revision: 19013000 Serial number: 0039DPHGVZFZ
    Coding: 0012342
    VCID: 3B22C7F0CF6FE943661-806E
    Subsystem 1 - Serial number: 6333FTS611752078
    Subsystem 2 - Serial number: 6343FTS683682408
    Subsystem 3 - Serial number: 6353ETS67IDCUVNP
    Subsystem 4 - Serial number: 6363ETS67ADCUVNP
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 AD HW: 3C0 953 549 AD
    Component: J0527 0020
    Revision: 00026000 Serial number: 3C5953507BA
    Coding: 0000003
    VCID: 6E843EA4CC9D4CEB91F-803A
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 960 N HW: 3C0 920 960 N
    Component: KOMBIINSTRUMENT VD1 1216
    Revision: V0002000 Serial number: 00000000000000
    Coding: 0007405
    Shop #: WSC 00856 067 57207
    VCID: 2E04FEA40C1D0CEBD1F-807A
    Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
    Part No SW: 3C0 907 530 H HW: 3C0 907 951
    Component: J533__Gateway H13 0142
    Revision: H13 Serial number: 2600P088130277
    Coding: F9801F06000202F101
    VCID: 2614068424ED44AB29F-8072
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 AB HW: 3C0 959 433 AB
    Component: IMMO 043 0383
    Revision: 00043000 Serial number: 00000000000000
    Shop #: WSC 98047 1011 1835006
    VCID: 6A8C32B4F075A0CBCD7-803E
    Subsystem 1 - Part No: 3C0 905 861 G
    Component: ELV 027 0380
    3C0905861G ELV 027 0380
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
    Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
    Component: J386 TUER-SG FT 1518
    Revision: 72009005 Serial number: 00000021488721
    Coding: 0000565
    VCID: 6FBA23A0CB9745E39A9-803A
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 194 2301
    Revision: 00H15000
    VCID: 2A0CF2B430F560CB0D7-807E
    Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 043 0472
    Coding: 01910A0801860E763004941570085BCE103CA1
    Shop #: WSC 00046 412 819200
    Subsystem 1 - Component: Sounder No Answer
    Subsystem 2 - Part No: 3C0 951 171 C
    Component: Neigungssensor 004 0611
    Subsystem 3 - Part No: 3C0 951 171 C
    Component: Innenraumueberw.004 0611
    1 Fault Found:
    01134 - Alarm Horn (H12)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 110
    Mileage: 236368 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 15:26:25
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
    Component: J387 TUER-SG BT 1518
    Revision: 72009005 Serial number: 00000769388702
    Coding: 0000564
    VCID: 70B820DCD6A95A1B833-8024
    Address 53: Parking Brake Labels: 5N0-907-801.clb
    Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
    Component: J540 EPB3 VW-10498 0003
    Revision: 009 Serial number: 00000000120237
    Coding: 0010000
    VCID: 280808BC2EF952DB1B3-807C
    4 Faults Found:
    01087 - Basic Setting Not Performed
    000 - - - MIL ON
    Freeze Frame:
    Fault Status: 11110000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 111
    Mileage: 236375 km
    Time Indication: 0
    Freeze Frame:
    Voltage: 13.70 V
    Count: 43
    Speed: 0.0 km/h
    Hex Value: 0x1250
    Hex Value: 0x0001
    Hex Value: 0x0101
    03190 - Incorrect Vehicle Type
    000 - - - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 111
    Mileage: 236375 km
    Time Indication: 0
    Freeze Frame:
    Voltage: 13.70 V
    Count: 98
    Speed: 0.0 km/h
    Hex Value: 0x1240
    Hex Value: 0x0001
    Hex Value: 0x0101
    01042 - Control Module; Not Coded
    000 - - - MIL ON
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 111
    Mileage: 236375 km
    Time Indication: 0
    Freeze Frame:
    Voltage: 13.70 V
    Count: 100
    Speed: 0.0 km/h
    Hex Value: 0x1250
    Hex Value: 0x0001
    Hex Value: 0x0101
    01279 - Longitudinal Acceleration Sensor (G251)
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    Freeze Frame:
    Fault Status: 11110101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 111
    Mileage: 236375 km
    Time Indication: 0
    Freeze Frame:
    Voltage: 13.60 V
    Count: 101
    Speed: 0.0 km/h
    Hex Value: 0x1240
    Hex Value: 0x0001
    Hex Value: 0x0101
    Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
    Component: Radio RCD310 012 0029
    Revision: 00000000 Serial number: VWZ1Z2H5776996
    Coding: 0500040004
    VCID: 65964188156B8FB3E05-8030
    End----------(Elapsed Time: 01:09, VBatt start/end: 13.5V/13.5V)-----------
  2. Re: 2008 Passat 1.9tdi Parking Brake Fault
    Oct 2017
    London
    12 Post(s)
    If it helps any I can clear all the faults down to the "03190 - Incorrect vehicle type" and drive with the parking light solid (not flashing as before)
    EPB illuminates when pressed on but Auto Hold does not light at all when pressed.
  3. Re: 2008 Passat 1.9tdi Parking Brake Fault
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    The parking brake module of this era is renown for flaky software faults.
    I had a Passat, same year, it gave a fault code for the handbrake fault light being " short to earth " , the light still worked fine.
    Even the handbrake worked fine although no Auto Hold, but because it brought the fault light up, needed fixing for the MOT.
    I did put a post on here about it a few years ago.
    The easiest way out was to replace the PB module. ( Usually find cheap on eBay )
    Once coded & basic settings performed, worked fine for the following few years ownership.
    By Jon44w in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-02-2021, 05:11 PM
  2. 2008 Passat 1.9tdi Parking Brake Fault
    Last Post: 18-02-2021, 05:08 PM
  3. 2008 Passat 1.9tdi Parking Brake Fault
    Last Post: 18-02-2021, 05:02 PM
  4. VW Passat Parking Brake Fault
    By 520735RIK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-09-2009, 01:51 PM
  5. Please Help passat parking brake fault
    By anita1mccoy in forum New Member Introductions
    Last Post: 26-01-2009, 05:56 PM
