Thread: Car starts then stalls [VCDS READOUT inc]
Results 1 to 10 of 14
Hybrid View
  1. Unhappy Car starts then stalls [VCDS READOUT inc]
    Nov 2019
    united kingdom
    Hi all, I'll keep it brief.
    Last week during this phase of bitterly cold weather my car wouldn't start. The car would start for a few seconds then stall and the glow pplug light would constantly flash. I just assumed it was that and replaced all four glow plugs, some of which did measure high resistance. So after doing that and also charging up my battery to make sure. I tried to start the car multiple times today with no luck. Same running for a second then stalling.
    This is the scan after I cleared all the DTC's so just the stuff that came back.
    The car came with one key. A year or two ago I got a second key coded by a non-dealership company. Tried both keys and no luck with either.
    I've noticed today along with the coil/glowplug light flashing the dash also says "dEF Safe"
    I can post the VCDS scan prior to clearing the codes if that'll help
    Any ideas with this?
    Thank you
    Code:
    Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
      67 69 75 76 77
    VIN: WAUZZZ8E15A053662  Mileage: 347210km-215746miles
    Address 01: Engine  Labels: 038-906-019-AVF.lbl
      Part No: 038 906 019 LJ
      Component: 1,9l R4 EDC 0000SG  5934
      Coding: 00002
      Shop #: WSC 63251
      VCID: 6A8C35B01566962BCD6-4B1E
      WAUZZZ8E15A053662  AUZ6Z0D0266042
    1 Fault Found:
    17978 - Engine Start Blocked by Immobilizer
      P1570 - 35-00 -
    Readiness: 0 0 1 1 1
    Address 03: ABS Brakes  Labels: 8E0-614-517.lbl
      Part No: 8E0 614 517
      Component: ABS/ESP front  4529
      Coding: 04255
      Shop #: WSC 06435
      VCID: 6596468CFC78B953E04-51CE
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
      35-00 - -
    Address 08: Auto HVAC  Labels: 8E0-820-043.lbl
      Part No: 8E0 820 043 AA
      Component:  A4 Klimaautomat  1424
      Coding: 00000
      Shop #: WSC 63251
      VCID: 60985798E35ADC7B132-5160
    No fault code found.
    Address 09: Cent. Elect.  Labels: 8E0-907-279-8E2.lbl
      Part No: 8E0 907 279 F
      Component: int. Lastmodul  RDW 0517
      Coding: 00001
      Shop #: WSC 63251
      VCID: 3536D6CC0C5809D3904-4B00
    1 Fault Found:
    01794 - Control Module - Incorrect Chassis (VIN) Number
      35-00 - -
    Address 15: Airbags  Labels: 8E0-959-655-84.lbl
      Part No: 8E0 959 655 J
      Component: Airbag 8.4EP  1002
      Coding: 0010602
      Shop #: WSC 63251 000 00000
      VCID: 3E24C9E03C6ECA8B41E-5184
    Address 16: Steering wheel  Labels: 8E0-953-549.lbl
      Part No: 8E0 953 549 S
      Component: Lenksáulenmodul  0611
      Coding: 01012
      Shop #: WSC 63251
      VCID: 43D2B814528CA7632E0-4B00
    Address 17: Instruments  Labels: 8E0-920-9xx-8E2.lbl
      Part No: 8E0 920 950 M
      Component: KOMBI+WEGFAHRS. RB4 D42
      Coding: 00401
      Shop #: WSC 00001
      VCID: 3332E8D4022C17E3BE0-5184
    2 Faults Found:
    01177 - Engine Control Unit
      65-10 - Unauthorized - Intermittent
    65535 - Internal Control Module Memory Error
      00-00 - -
    Address 45: Inter. Monitor  Labels: 8E0-951-177.lbl
      Part No: 8E0 951 177
      Component: Innenraumueberw.  0704
      Coding: 00001
      Shop #: WSC 00000
      VCID: 6B8230B41A9C8F23B60-5118
    Address 46: Central Conv.  Labels:. 8E0-959-433-MIN.clb
      Part No: 8E0 959 433 BD
      Component: Komfortgerát TBF  1712
      Coding: 07147
      Shop #: WSC 00673
      VCID: 74B02BC847A250DB67A-4B00
      Subsystem 1 - Part No: 8E2959802B
      Component: Tőrsteuer.FS BRM 0205
      Subsystem 2 - Part No: 8E2959801B
      Component: Tőrsteuer.BF BRM 0205
    Address 56: Radio  Labels: 8E0-035-1xx-56.lbl
      Part No: 8E0 035 186 D
      Component: concert II  GRO  0004
      Coding: 01001
      Shop #: WSC 63251
      VCID: 28080FB8CBDA643B1B2-4B00
    Address 76: Park Assist  Labels: 8Z0-919-283.lbl
      Part No: 8Z0 919 283 A
      Component: Parkingsyst. A4 RDW D09
      Coding: 00114
      Shop #: WSC 63251
      VCID: 43D2B81452BCA7632E0-5160
    End----------(Elapsed Time: 05:40, VBatt start/end: 12.4V/12.4V)-----------
  2. Re: Car starts then stalls [VCDS READOUT inc]
    134 Post(s)
    2007 Post(s)
    The “def” message means the instrument cluster is defective and will have to be repaired or replaced, the immobiliser is integral with the cluster BUT it does not mean the key or reader coil are not also faulty.
  3. Re: Car starts then stalls [VCDS READOUT inc]
    Nov 2019
    united kingdom
    Thanks for the reply Crasher, Do you know if the cluster can be replaced and re-programmed with VCDS? If so, I should be able to grab a second hand cluster off ebay for reasonable ŁŁ I'm guessing.
    I've been spending a whole lot on this car and it's on the verge of being made into tin cans at this point haha.
  4. Re: Car starts then stalls [VCDS READOUT inc]
    134 Post(s)
    2007 Post(s)
    A replacement cluster can no longer be matched to the key and the engine ECU using VCDS as the old seven digit SKC method has been dropped. In theory the four digit PIN can be retrieved but often this does not work but some mobile key specialists do have the kit (typically VAG TACHO) to do this but it rarely worked for me so now I use the VAG dealer system ODIS and even that struggles if the used cluster has VIN based component protection which yours does. Unfortunately the cluster for your car 8E0 920 950 MX went obsolete from the mainstream VAG parts system last April and it is not yet available on Audi Tradition and if it was you would still be stuck because at the moment they are not accepting orders from the UK! I think your easiest solution is to see if a car electronics repair service such as http://www.bba-reman.com can help as they SHOULD be able to retain the immobiliser coding.
    0 2 0
  5. Re: Car starts then stalls [VCDS READOUT inc]
    Nov 2019
    united kingdom
    Wow, thank you for the fast and detailed response, as you know a heck load more than me, how much would you estimate resolving something like this costing if you had to guess? I have no idea but I'm wondering if it's time for a new car as this audi has been a lot of trouble and don't know if its worth saving as I feel like electrical problems are big ŁŁŁŁ to resolve.
    What should I ask from http://www.bba-reman.com, send them my cluster for repair right?
  6. Re: Car starts then stalls [VCDS READOUT inc]
    Nov 2019
    united kingdom
    Just called them, sounded like it'd be a few hundred to sort it possibly but upon looking them up the reviews seem dreadful https://uk.trustpilot.com/review/shop.bba-reman.com
    do you know of anyone using them successfully?
  7. Re: Car starts then stalls [VCDS READOUT inc]
    134 Post(s)
    2007 Post(s)
    They went through a bit of a nightmare a year or so back, the US operation collapsed apparently due to mismanagement and it took Chris Swan some huge effort to get it back on its feet, you could try mail but they have messed me around in the past; basically all these companies are working on a knife edge and it is only going to get worse as cars fall into the so called "electronics legacy trap". Your car is only sixteen years old and already an operation critical component is obsolete. We had a lovely condition A4 estate 96 1.8 20v we used as a loan car but we missed that the plenum chamber was blocked and water got into the passengers side. We dried everything out but a year or so later the left side impact air bag crash sensor failed due to corrosion of the pins, it was a 1996 only part and completely impossible to find so the car had to be scrapped. I could have disabled the side air bags and got the light to go out but if we lent it to someone and they were in an accident where the airbag would help them, we would be in deep ****. The same is going to happen with 8+ year old electric cars when the battery fails, they will be scrapped and that is NOT environmentally friendly!
    0 2 0
  1. Question A4 Starts But Immediately Stalls
    By Monzta in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-08-2019, 03:13 PM
  2. Engine starts then stalls after a second when hot !
    By bogdanvrg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-04-2017, 10:19 PM
  3. 2.0 FSI Starts then immediately stalls?
    By samrimmer in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-07-2014, 09:54 PM
  4. VR6 Starts then Stalls
    By iep in forum Golf MK3 - 1993 - 1999
    Last Post: 13-02-2008, 09:09 PM
  5. a3 starts and stalls
    By dolly in forum Audi A3 - Archive Topics
    Last Post: 05-06-2007, 06:01 PM
