Thread: Ignition switch issues
  1. Ignition switch issues
    Feb 2021
    England
    Hi, i have 2005 Audi A6 2.7 s-line, I've changed the ignition switch, but it's still not working, does the car need telling it's had a new 1, through the ecu or something? Any help would be appreciated.
  2. Re: Ignition switch issues
    Aberdeen
    63 Post(s)
    I have moved this to the correct section.
    Cheers, Scott
  3. Re: Ignition switch issues
    1840 Post(s)
    There are seven different 4F ignition switches, are you sure you have the correct one and that the old one is faulty? It is called the "Entry and start authorisation switch E415" and is not codded to the immobilser or even the key. Does it start and then stop or not turn over or just turns over?
  1. Replies: 3
    Last Post: 15-12-2015, 09:04 PM
  2. ignition switch
    By raymondbilko in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-02-2011, 09:36 PM
  3. Ignition switch
    By lawser in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 20-10-2010, 08:58 PM
  4. Ignition switch
    By SammoVWT in forum Golf MK3 - 1993 - 1999
    Last Post: 09-07-2010, 12:39 PM
  5. Please Help Ignition switch issues results no power to head unit
    By Adampski in forum Golf MK3 - 1993 - 1999
    Last Post: 25-06-2010, 10:46 PM
