Thread: 2010 A6 Avant drivers side rear window not fully closing
  1. 2010 A6 Avant drivers side rear window not fully closing
    Jan 2009
    Derby
    Hi everyone...
    My boy opened his window this morning, but it wouldn't fully close, and was still open by around 6 inches. If we tried to close it further, it either wouldn't move, or the window would go down, as if the sensor had detected an obstruction.
    I managed to close it once we arrived home by fully opening it, and then pulling up on the window whilst also trying to close with the switch. However, I can see the that it is not fully closed along the top rear edge of the window.
    I have tried searching but can't find anything specific to this model - I'm guessing the guides have broken, causing obstruction. But I'm wondering if anyone else has had the same issue?
    Thanks!
    2011 (61) Audi A6 Avant 3.0 TDi Quattro Special Edition - Quartz Grey
  2. Re: 2010 A6 Avant drivers side rear window not fully closing
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    Had this on mine some silicone rubber spray fixed it
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: 2010 A6 Avant drivers side rear window not fully closing
    Jan 2010
    kent, england
    10 Post(s)
    We had this, it happened when we tried opening the windows when they were frozen, it loosened the clamp on the riser and so wouldn’t go up straight. I took the door panel off, tightened it all and greased as Dean says and it was fine. You can get the window shut for now by opening the door and have someone raise the window whilst you guide it up from inside and outside.
  4. Re: 2010 A6 Avant drivers side rear window not fully closing
    Jan 2009
    Derby
    Thanks both. I've got the window shut, and looks like I'll be taking the door panel off this coming weekend.
    I've got a leak on the headlight washers to take a look at too, although that looks to be more tricky. Possibly bumper off job.
  5. Re: 2010 A6 Avant drivers side rear window not fully closing
    Dec 2007
    44 Post(s)
    Got that on mine too lol, fill it up few days later it’s empty
  6. Re: 2010 A6 Avant drivers side rear window not fully closing
    Jan 2009
    Derby
    I had it on my last A6 too (a 2011 c6) but the garage fixed that for me. I've been looking at it and think it may be a bumper off job.
    Have had the rear inner tail lights off today to wet sand and polish them. Ended up removing the lights to make it easier. So the washer fluid leak will have to wait for now.
  1. Question widow glass rattles when closing door - if the window isn't already fully closed
    By headache56 in forum Golf MK7 - 2013 - 2019
    Last Post: 23-07-2019, 05:55 PM
  2. Drivers Window Slow closing
    By supersiecosse in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-03-2015, 01:03 AM
  3. a6 se v6 rear window not closing fully?
    By Blitzskymaster in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 22-06-2014, 03:37 PM
  4. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  5. A4 Cabriolet - Window not closing fully after shutting door - Ice
    By tag2312 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-01-2010, 10:13 AM
