Thread: 05 Touran emissions warning and paint code!
Results 1 to 10 of 16
  1. 05 Touran emissions warning and paint code!
    May 2010
    edinburgh
    Hi all, have been on this forum for years on and off with Passat and audis, been hugely helpful!
    Have just got a 55 plate 1.9tdi with BKC engine, the Mel light was on and emissions warning. Scanned with relatively cheap scanner and came up with egr flow restricted..p401..I think!
    Is there anything else can cause this apart from the egr needing cleaned? Cleared the code hasn't returned so far.
    I also have a couple of wings to paint and fit, but no sign of the paper sticker in back with paint code...is it anywhere else on the car, or can anyone point me to a good place to get paint mixed by reg number, or vin?!
    Any help greatly appreciated, Adam
  2. Re: 05 Touran emissions warning and paint code!
    May 2010
    edinburgh
    Anyone?
  3. Re: 05 Touran emissions warning and paint code!
    1840 Post(s)
    Private message me the REG or VIN
  4. Re: 05 Touran emissions warning and paint code!
    May 2010
    edinburgh
    Hi Crasher, thank you having problems getting onto private message system, will do on laptop when get home. Appreciated
  5. Re: 05 Touran emissions warning and paint code!
    May 2010
    edinburgh
    So have sorted paint match, has no one had this emissions warning, and eml light?
    There's plenty on the net but not found anything specific.
    It's a bkc engine. Any help or pointers be greatly appreciated.
  6. Re: 05 Touran emissions warning and paint code!
    1840 Post(s)
    You need to get it scanned with VCDS.
  7. Re: 05 Touran emissions warning and paint code!
    May 2010
    edinburgh
    Ok, thanks for that. Anyone around Stirling or Perth, or even Edinburgh got vcds! Be happy to cover time 🙂
  8. Re: 05 Touran emissions warning and paint code!
    1840 Post(s)
    The paint code is LB5N Indigo Blue pearl. You may have a clogged inlet system after the EGR valve
  9. Re: 05 Touran emissions warning and paint code!
    May 2010
    edinburgh
    Wow..crusty. If that's what it is, can I clean it in situ, or dismantle further back from the egr? Am going to take apart at the weekend. And thanks for the code..was taking a bit of old wing in to match, but that will help greatly. Appreciated
  10. Re: 05 Touran emissions warning and paint code!
    1840 Post(s)
    Because time is money I tend to at least fit a new EGR valve as they cost about the same as my labour rate to clean and often the V157 flap as well but the manifold is expensive so we take them off, scrape as much out as possible and then leave it to soak of strong TFR overnight and then pressure was clean.
  1. Question Touran Emissions garage
    By granttd73 in forum Touran - Sharan - Caravelle
    Last Post: 02-03-2020, 05:49 PM
  2. Workshop emissions warning and yellow warning light
    By Lewes96 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-11-2014, 10:05 PM
  3. Paint code(s) or paint for 20" Rotor wheels
    By john2107 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-03-2014, 10:49 AM
  4. Question Touran paint code
    By masterinengland in forum Touran - Sharan - Caravelle
    Last Post: 15-09-2011, 11:05 AM
  5. Please Help Emissions Warning Light On, Fault code reads misfire...but she runs just fine!
    By michaelwoodward in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-02-2010, 03:09 PM
