Thread: Po116 fault codes
Results 11 to 20 of 22
  1. Re: Po116 fault codes
    Feb 2020
    Bradford
    40 Post(s)
    If you want to get to the bottom of this dpf present or not issue post a close up picture of the exhaust tailpipe, if it's got a working dpf we will see the metal in its natural colour minus a little bit of soot, if a dpf is not present it'll be black soot.
    If soot is present perhaps then we could look for remnants of the system
  2. Re: Po116 fault codes
    Nov 2013
    west midlands
    I’m not sure what work it’s had done at all
    The fault code only seems to have come up when I turned the engine off then switched the ignition on to plug in the code reader is that makes any difference
  3. Re: Po116 fault codes
    Nov 2013
    west midlands
    The stutter only happens between 1800 revs and 3000 then it clears up
    Does anyone know what turns off if you disconnect the maf on a vw
    Worth chucking in a boost sensor ?
  4. Re: Po116 fault codes
    Nov 2013
    west midlands
    I disconnected the maf sensor
    It does have a small stutter but nowhere near as bad as normal almost perfect in fact
    The coolant temp fault has come back and I’m confused as can’t see
    Anything obvious with vagcom
    The temp on the display behaves fine the heater heats up quickly
  5. Re: Po116 fault codes
    134 Post(s)
    2003 Post(s)
    If the Air Mass Meter is disconnected the ECU reverts to a default base map using other sensors. If being disconnected changes the way it runs it doesn't necessarily mean the AMM is at fault as the default map could cover up another error as it sounds like it is running lean. Remember you will have generated an AMM open circuit code.
  6. Re: Po116 fault codes
    Nov 2013
    west midlands
    Thanks I’ve replugged in and cleared t the fault
    The car mainly stutters when going up a hill with light acceleration if you drive a bit quicker it runs as normal
  7. Re: Po116 fault codes
    #17
    134 Post(s)
    2003 Post(s)
    If you do fit a new AMM, only buy it genuine from VW or TPS, if you fit an aftermarket one, even Bosch, and you still have the problem you won't know if it is the new AMM or not.
  8. Re: Po116 fault codes
    #18
    Nov 2013
    west midlands
    What about the boost sensor or boost pressure sensor would they cause this issue
  9. Re: Po116 fault codes
    #19
    134 Post(s)
    2003 Post(s)
    16500(P0116) - Engine Coolant Temp. Sensor (G62): Implausible Signal
    I only just noticed the fault code in the title.
  10. Re: Po116 fault codes
    #20
    Nov 2013
    west midlands
    I don’t have any fault codes and the p0116 is still there even after sensor change
  1. Question Fault Codes
    By Jak68 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-03-2019, 12:32 AM
  2. Please Help A3 Fault codes Radio Fault
    By MAFED in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 02-05-2010, 04:21 PM
  3. Fault Codes
    By rayTTsmith in forum TT - 8N Forum - 1998 - 2006
    Last Post: 07-08-2009, 06:26 AM
  4. VAG COM Fault codes
    By wcb in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-08-2009, 08:32 PM
  5. any one had these fault codes??
    By Adamtdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-02-2008, 12:27 AM
