Thread: Po116 fault codes
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Po116 fault codes
    Nov 2013
    west midlands
    Have this on my 2.0 tdi golf 2011
    Temp gauge behaves as normal and gets to 90 and stays there
    Topped up coolant
    What else could it be as can’t think of anything obvious
  2. Re: Po116 fault codes
    134 Post(s)
    2002 Post(s)
    P0116, not o116. Firstly, replace the temperature sender and if that does not work, the thermostat.
  3. Re: Po116 fault codes
    Nov 2013
    west midlands
    This is what vagcom says and the dial is at 90 degrees with the engine running on my drive.
    I gather you mean the coolant tempreture sensor
    What’s weird is the code doesn’t show up on a generic code reader but it you click read codes it pops up
    I can’t get the fault code to show again in vagcom so must be a cold start issue but I did see it last week
  4. Re: Po116 fault codes
    Nov 2013
    west midlands
    Just to confirm the heater heats up very quickly and works really well even when on full speed
  5. Re: Po116 fault codes
    Nov 2013
    west midlands
    What’s also weird is I don’t have the management light on which seems to be associated with this fault
    The temp gauge goes up as you would expect and sits at 90 and never moves
  6. Re: Po116 fault codes
    Nov 2013
    west midlands
    Coolant temp sensor changed
    What a ***** place to put it lol
    Temp figure lot closer together to what’s on there dash now and the temp gauge does go down when heaters wacked up on idle
    No fault codes on vagcom either
    My stuttering issue at 1800 revs when cruising along seems to be better as well
    Not bad for a 7 quid part
    Many thanks
  7. Re: Po116 fault codes
    134 Post(s)
    2002 Post(s)
    The reason it does not show us on a generic reader is typical of generic OBDII reader, i.e. effin useless, often misleading and sometimes dangerous, don't waste your time and money on anything but VCDS. The MIL not coming on is normal until the fault causes an emissions issue, it is why when people come on here and describe a problem but say there are no lights on so there can't be a fault; that I get irritated.
  8. Re: Po116 fault codes
    Nov 2013
    west midlands
    Drove home stuttering between 1800 and 3000 revs is back
    Plugged in and coolant sensor fault has come back
    I haven’t deleted it so it will flag on vagcom
    Will plug it in and tomorrow and give the exact details. I have had the coolant sensor fault on vagcom but didn’t take a picture of the wording
  9. Re: Po116 fault codes
    Nov 2013
    west midlands
    I do believe the car has dpf off (no proof but the dpf light doesn’t sync test at start up )
  10. Re: Po116 fault codes
    134 Post(s)
    2002 Post(s)
    If it has had a DPF delete and associated software manipulation, personally I am stuck.
  1. Question Fault Codes
    By Jak68 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-03-2019, 12:32 AM
  2. Please Help A3 Fault codes Radio Fault
    By MAFED in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 02-05-2010, 04:21 PM
  3. Fault Codes
    By rayTTsmith in forum TT - 8N Forum - 1998 - 2006
    Last Post: 07-08-2009, 06:26 AM
  4. VAG COM Fault codes
    By wcb in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-08-2009, 08:32 PM
  5. any one had these fault codes??
    By Adamtdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-02-2008, 12:27 AM
