Thread: B7 s4 clutch issues
Results 1 to 10 of 10
  1. B7 s4 clutch issues
    Dec 2018
    cardiff
    Hi my B7 S4 has started to have some trouble changing gear, its gone from silky smooth to slightly notch when selecting gears
    the pedal also feels quite light and spongy
    am I looking at a new clutch? if so how much is a reputable indie going to charge?
    whilst I know its how the car gets driven, its only just over 70K is that not a bit early for a clutch
    I never abuse the car and I don't believe the previous owner did (although obviously I cant be 100% sure on that)
    could it be something more simple?
    im taking it too a reputable place to get it looked at, but id be interested to hear anyone's thoughts on it
  2. Re: B7 s4 clutch issues
    Jan 2009
    Birmingham
    36 Post(s)
    Does it happen when the car is all warmed up?
  3. Re: B7 s4 clutch issues
    134 Post(s)
    2007 Post(s)
    Typically you would pay about £1k for a full LUK DMF clutch rep set fitted and done, any less should ring alarm bells.
  4. Re: B7 s4 clutch issues
    Dec 2018
    cardiff
    Quote Originally Posted by arman123 View Post
    the car is used very little, but lately its been used for a work run, which is about 20 minutes
    so not sure if that`s anything to go buy?
  5. Re: B7 s4 clutch issues
    Dec 2018
    cardiff
    Thanks for the reply, sounds about right from what ive read
    is it 100% certain that the flywheel needs changing? or is it a case of just a well do it if its out
  6. Re: B7 s4 clutch issues
    Dec 2018
    cardiff
    Quote Originally Posted by raybrig View Post
    Any thoughts on this? as the clutch is not actually (slipping) its as described, a spongy/soft pedal
    with (slight) trouble getting the lower gears
    also some advise on the clutch price, ive a pal at a local motor factors that i can get 20% on the retail price
    if i know what (exactly) i need
    only want a standard replacement, no after market
    ive had the car for around 18 months and not really had any issues, im not really up on the model so its a steep
    learning curve, so any advise welcome
    also based in the cardiff area, so any good independants that know these cars?
    only one i keep getting is Euro Performance llantrisant
  7. Re: B7 s4 clutch issues
    134 Post(s)
    2007 Post(s)
    Anyone who changes a clutch and leaves the DMF alone is putting themselves at risk of having to do the job again for free; do it right and do it once with all matching top quality parts so either genuine VAG, Sachs or my favourite way, a full 4 piece LUK Rep set including flywheel to crank and pressure plate bolts.
  8. Re: B7 s4 clutch issues
    Dec 2018
    cardiff
    Thanks for the info, after doing some research it seems that doing the DMF along with the clutch is the way to go
    as said, ive not had a lot experience with the car (being broken) so need to learn pretty quick
    also as you mentioned, the LUK set up seems to be the one to go for if after a standard set up, which is what i want
    can get a good discount from a pal that works at a moto factors, ive had a quick look but only coming up with standard
    A4 kits, not the B7 S4 kit so ive not got anything to compare prices with as of yet
    70k + a little low for a clutch change on these cars or is just the way it is? after a quick look anything from 60k to 100k plus
    seems to be acceptable
    got to be honest i bought the car on 68k and wasn't expecting a clutch change this soon
  9. Re: B7 s4 clutch issues
    134 Post(s)
    2007 Post(s)
    It depends on how it has been driven. I get the LUK clutch kit number to be 624 3311 00 and the flywheel as 415 0230 10, it doesn’t look like they do a full kit
  10. Re: B7 s4 clutch issues
    Dec 2018
    cardiff
    bit of an update, the car is still the same as before and defiantly needs doing, im getting it checked over by my usual mechanic (experienced)
    to see if it is in fact the clutch, as before the pedal is very soft/spongy with no real (push-back) ive got to be very gentle when letting off the clutch pedal
    on your price quote you say £1k is this for the clutch and the DMF fitted?
    As looking on getting this done and had a quote of nearly 3k from a local VW specialist, which seems High-regardless, they did want me to also have the chains done
    which would have been nearer 6k
    also another place has quotes 2k for cash (parts supplied) without fully removing the engine, so im at bit off a loss on what to do, my mechanic is very competent, but he admitted to not having done a clutch on one of these, would this be any issue for a competent mechanic, or best give to someone who knows the cars and done one before
    i believe the clutch and DMF is around £800 although as said can get a heft discount if i get the parts myself and let my guy fit them
    where as the 2k quote wants to supply all the parts needed, i assume to off-set doing the the job cheaper for cash?
    id be very great full for any advise at all, also in the CARDIFF area
  1. A4 b6 CLUTCH ISSUES
    By domy123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-05-2010, 11:25 AM
  2. Please Help AZD Clutch Issues !
    By belfastmark in forum Golf MK4 - 1999 - 2004
    Last Post: 26-04-2010, 07:16 PM
  3. Please Help Clutch issues
    By peteisfishing in forum Bora - 1998 - 2005
    Last Post: 24-11-2009, 10:06 PM
  4. Clutch Issues?
    By j41brs in forum Golf MK3 - 1993 - 1999
    Last Post: 18-11-2008, 06:42 PM
  5. Question Clutch Issues
    By stevetow in forum Chat - Anything with wheels
    Last Post: 29-08-2008, 10:58 AM
