Thread: Heater blower motor
Results 1 to 8 of 8
  1. Heater blower motor
    Wales
    Hi, can the heater blower motor be replaced without removing the glove box on 2011 b7 passat? Thx in advance all replies.
  2. Re: Heater blower motor
    1840 Post(s)
    I think you have to but personally never done one, one of our chaps did one a few weeks ago as they are becoming a common failure so I will ask him tomorrow.
  3. Re: Heater blower motor
    Wales
    Thank you very much.
  4. Re: Heater blower motor
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    I'm pretty sure it will be the same as my Superb.
    Lay on your back with your backside out the door ( very uncomfortable ).
    Undo the 2 finger screws holding a plastic sheet under the glovebox.
    Once that's out of the way you can see the blower motor.
    Undo a Philip's screw, lift a plastic tab & turn the whole motor unit clockwise ( could be anti-clock ) about 20 degrees & it just falls out.
  5. Re: Heater blower motor
    Wales
    After laying in a position resembling Yuri Gagarin just before launch , I managed to get the old one out but it was so tight a squeeze I do not want to risk the ruin of my new motor , the bottom part of the glove box was completely in the way and only by undoing the t15 torx screws that run along the lower part of the glovebox , was I able to release the old unit , and even then it was very difficult to drop the unit down . I can ,I think , remove/replace the glovebox but I am worried I may damage the new unit upon refitting so I am taking it to my local (non VW) garage tmrw , weather permitting ofc.
  6. Re: Heater blower motor
    Wales
    Thanks for the help , it is a pity that VW don't make easier access to modules , great engineering but over done.
  7. Re: Heater blower motor
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Must be a different design to my Superb.
    Although awkward, changed mine in about 20 mins.
    Hope you get it sorted quickly.
    You can't drive in this weather without a heater & blower.
  8. Re: Heater blower motor
    Wales
    Exactly , but all done now and it was impossible without the glove box removed , although I did remove the old unit with the glove box intact , it would have meant certain damage replacing the new unit the same way , the bottom of the glove box on the b7 passat covers the part of the motor housing. Changed the resistor and pollen filter same time . Thx for reply.
    By nigedvd in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 06-07-2015, 10:43 PM
  2. Heater Blower Motor removal
    By brightside in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-10-2011, 10:25 PM
  3. heater blower motor
    By aaman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-09-2008, 12:26 AM
  4. Heater Blower Motor or something else?
    By Audi 80 Man in forum 80 - 90
    Last Post: 08-01-2008, 06:54 PM
  5. S reg A3 - Accessing Heater Blower Motor
    By kimi in forum Audi A3 - Archive Topics
    Last Post: 26-10-2007, 10:54 AM
