Thread: Diesel Fuel Filter Change
  1. Diesel Fuel Filter Change
    Jan 2021
    solihull
    My mk5 2.0 diesel takes a few turns of the key to start sometimes, the RAC chap said probably fuel filter, so i am changing this as it seems fairly straight forward but is there anything to look out for? air locks etc?
    thanks
  2. Re: Diesel Fuel Filter Change
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Think you will need one of those fuel pump syringes to draw fuel from the tank into the fuel filter and then form the fuel filter to the fuel rail / injectors otherwise you might get air in the system.
    The fuel filter will need to be primed with fuel initially and then from the filter to the injectors / rail will need to be primed.
  3. Re: Diesel Fuel Filter Change
    131 Post(s)
    1973 Post(s)
    If the filter is full of black sludge, you will need to replace the tandem pump. Ideally you should also clean the entire system out but it will clean itself eventually. The best way to fill the filter can is by running the fuel pump with VCDS.
  4. Re: Diesel Fuel Filter Change
    Oct 2017
    London
    12 Post(s)
    A camshaft sensor failure can also cause a slow start if the new fuel filter fails. This info will be stored in a scan.
  5. Re: Diesel Fuel Filter Change
    Mar 2007
    Suffolk
    Can I also fill filter can with diesel by hand ok?
  6. Re: Diesel Fuel Filter Change
    Oct 2017
    London
    12 Post(s)
    Quote Originally Posted by Mike McKinstry View Post
    Yes no problem at all.
  1. Replies: 2
    Last Post: 07-01-2018, 07:04 PM
  2. Air Leak in Diesel fuel line after Fuel Filter Replacement
    By CliffA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-05-2015, 09:55 AM
  3. audi a4 fuel filter and air filter change intervals??
    By sps in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-01-2014, 11:24 PM
  4. Please Help How do I change Diesel Fuel Filter on MK5 Golf
    By Crackshot in forum Golf MK5 - 2004 - 2009
    Last Post: 31-01-2011, 08:36 AM
  5. vw bora diesel fuel filter change?
    By sps in forum Golf MK4 - 1999 - 2004
    Last Post: 07-06-2010, 10:16 AM
