Thread: 2011 tiguan 140 tdi r line brakes
  1. 2011 tiguan 140 tdi r line brakes
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Evening all I have a 2011 60 plate tig r line 140 tdi ,6 speed manual, 4 motion.
    Would the rear brake calipers have wind in pistons or push back .
    Many thanks
    STUART
  2. Re: 2011 tiguan 140 tdi r line brakes
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    My son has 2012 Tiguan which has the EPB, assume yours is the same.
    The EPB needs to be wound back first, either with a diagnostic tool like VCDS or remove the EPB motor ( 2 torx screws ) & wind it back manually with a torx bit.
    Once EPB wound back, the piston pushes straight back, no winding required.
  3. Re: 2011 tiguan 140 tdi r line brakes
    1836 Post(s)
    That is a TRW caliper so put into pad change mode and wind back the piston.
  4. Re: 2011 tiguan 140 tdi r line brakes
    Aug 2018
    Kent, England
    Hello there
    you need a diagnostic tool to release them first and then they are push in... no need to turn. You can use water pump pliers to push them back in.
    I have got a video on replacement of rear pads and discs on 2012 tiguan which will be the same for yours.
    here is the link
    VW Tiguan mk1 and mk2 rear brakes replacement with electronic handbrake. Audi, Skoda and Seat - YouTube
    Stay Safe, Enjoy your Life and Check AlexTheGrumpyOne channel for Car related videos
    VW Tiguan 2012 2.0TDI
    VW Scirocco 2012 2.0TDI
    Toyota Supra mk4 2001
    Toyota Celica GT VVTL-I 2005
  1. R-Line Tiguan
    By RichA4 in forum Tiguan
    Last Post: 24-09-2017, 03:03 PM
  2. Question Tiguan R Line - Harsh Ride - Help
    By paul_uk_3000 in forum Tiguan
    Last Post: 18-07-2016, 06:39 AM
  3. Replies: 1
    Last Post: 20-01-2016, 01:21 PM
  4. Replies: 4
    Last Post: 24-07-2014, 12:29 PM
  5. Tiguan R Line
    By findmeinthetara in forum Tiguan
    Last Post: 05-04-2010, 06:54 PM
