Thread: A3 8V - 2.0TDI S-Line - Vehicle failure message on start-up - but no apparent failed lights/bulbs?
  1. A3 8V - 2.0TDI S-Line - Vehicle failure message on start-up - but no apparent failed lights/bulbs?
    Sep 2010
    Portrush, County Antrim. N.Ireland
    Hi folks.
    For the past month or so, there has been a Vehicle light failure showing when the ignition is turned on. The error stays when the engine is turned on.
    I've checked all the lights and bulbs on several occasions now with a member of my family and we cannot find anything that would suggest a failed bulb or light.
    I haven't tried reseating any of the bulbs.
    Just wondered if anyone had experienced anything similar?
    I've ensured that the main battery is fully charged too.
    No other faults with the car and I have had it since new from September 2013. Current mileage just past 90k.
  2. Re: A3 8V - 2.0TDI S-Line - Vehicle failure message on start-up - but no apparent failed lights/bulbs?
    Oct 2021
    Vwaudi1
    The way the Audis work by knowing of a light is out/ faulty is resistance and I have had this also on my S3.
    Are your lights on auto? I’m sure someone else will chime in but I’m presuming if might do a self check of all systems or it’s seeing maybe a drl error which could be high resistance not low ( low resistance would be a blown bulb )
    I personally would start obdeleven / vcds it may show you where the issue is and allow you to hone in on the area
    Good luck
  3. Re: A3 8V - 2.0TDI S-Line - Vehicle failure message on start-up - but no apparent failed lights/bulbs?
    Sep 2010
    Hi all.
    Audi released a new version of firmware to eliminate the 'false positive' light failure message. I had the update done by Audi in Belfast almost two months ago and the problem hasn't come back.
    Happy days.
  4. Re: A3 8V - 2.0TDI S-Line - Vehicle failure message on start-up - but no apparent failed lights/bulbs?
    1840 Post(s)
    Start with a code read of the Body Control Module.
  1. Q7 3.0TDI 2008 S-Line Keyless start issue
    By Rigy1979 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 24-09-2018, 01:55 PM
  2. A4 S-Line 2.0tdi won't start
    By farmerferret in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-02-2018, 01:04 PM
  3. 2007 A6 S-line 2.0tdi Auto Gearbox Failure HELP Needed
    By leotandoh12 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-08-2016, 09:51 PM
  4. A6 2.0TDI Avant S Line 2012 C7 Interior Lights issue.
    By Tigerdaly in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-01-2015, 11:08 PM
  5. Replies: 5
    Last Post: 28-11-2013, 12:54 AM
