Thread: Headlight Leveler
Results 1 to 10 of 10
  1. Headlight Leveler
    Mar 2017
    Hampshire UK
    I need to replace the leveler on a 2004 TDI Touran. Do I need to remove the headlight to do this?
    1 person in 10 understands binary, the other one doesn't.
  2. Re: Headlight Leveler
    1841 Post(s)
    The manual type with Halogen lights or the HID automatic system?
  3. Re: Headlight Leveler
    Mar 2017
    Hampshire UK
    It's the Halogen variety with the adjusting wheel under the light switch.
  4. Re: Headlight Leveler
    1841 Post(s)
    From memory I think you can rotate and unlock it in situ but I think it is difficult to unhook it from the reflector so bumper off and headlight out. It is the same part as the Golf 4 and Octavia 1 and on mine I had to take it out but Octavia 1 lights are very easy to remove.
  5. Re: Headlight Leveler
    Mar 2017
    Hampshire UK
    Thanks, I was hoping not to have to drop the bumper but - oh well...!
    When it goes back together, will it set itself by adjusting all the way down then all the way up, or is there a midway to find first?
  6. Re: Headlight Leveler
    1841 Post(s)
    In theory it should stay where it is but I would suggest a friendly MOT chaps help.
  7. Re: Headlight Leveler
    Mar 2017
    Hampshire UK
    Thanks, a job for next weekend.
  8. Re: Headlight Leveler
    Mar 2017
    Hampshire UK
    Out of curiosity, does it just do the dip reflector or does it adjust both?
  9. Re: Headlight Leveler
    1841 Post(s)
    On the Octavia 1 it is both as it is an H4 unit, I have never noticed if it is both on a Touran or others which use H7's.
  10. Re: Headlight Leveler
    Mar 2017
    Hampshire UK
    Just discovered both not working. Might have to wait for a change in the weather now.
  1. Please Help Headlight Coding Issue after Headlight Swapover
    By DeanoD in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-12-2020, 04:01 PM
  2. Question “Headlight Range Control Defective” after headlight removal
    By spikeheap in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-05-2019, 12:54 AM
  3. Replacing Headlight + Headlight Bulb on A3 Sline Black Edition 2011 Xenons
    By AudiRyda in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-06-2015, 07:32 PM
  4. Question DRL Headlight Value
    By colt3003 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-10-2014, 12:20 PM
  5. Headlight
    By A6_JAck in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-12-2010, 09:17 AM
