Thread: Brake pedal sometimes sinks to floor
  1. Brake pedal sometimes sinks to floor
    Jan 2021
    Leicestershire, England
    Hi guys, I've got an Audi A1 2011 1.6L TDI. I've noticed in the last few months that sometimes when I'm applying the brake pedal at low-medium speeds the pedal just sinks straight to the floor with very little brake effect (but there is some when it reaches the floor) if I lift my foot off the brake pedal and reapply it works perfectly. I don't really know where to start with this one, I've seen on other threads with people with similar problems mention the master cylinder. Any help would be appreciated. Thanks, Lewis.
  2. Re: Brake pedal sometimes sinks to floor
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    If your not loosing any brake fluid, it will almost certainly require a new master cylinder.
    Some you can get new seals fitted, but newer cars tend need a complete new MC as replacement seals are not available.
  3. Re: Brake pedal sometimes sinks to floor
    1841 Post(s)
    That is an extremely unusual failure and considering it is used right across the group in the Polo (hence the 6R prefix for the part number), Ibiza, Toledo, Fabia and Roomster if it was common there would be technical product information notices about it. I would have the master cylinder replaced as a precaution. It is right hand drive specific and the VAG number is 6R2 611 019 B REP which is £223, it was originally made by ATE and at the moment is not available aftermarket from what I can see.
  4. Re: Brake pedal sometimes sinks to floor
    Jan 2021
    Its 2011 I don’t know if that counts as a new car. But thanks I’ll look into getting it replaced
  1. Question Brake pedal goes to floor randomly, no leaks, no air, brakes work fine otherwise
    By Lozzy90 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-10-2019, 10:47 PM
  2. Brake Pedal Went to the Floor
    By taxi3528 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-10-2015, 08:39 PM
  3. Please Help Changed Brake Fluid Yet Pedal Goes To Floor
    By mercedeslimos in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-12-2011, 12:46 PM
  4. Please Help Brake pedal goes to floor
    By kezq in forum The Commercial Range
    Last Post: 21-05-2010, 11:06 AM
  5. brake pedal sinks
    By audijay73 in forum 80 - 90
    Last Post: 20-01-2010, 10:31 AM
