HI - Wondered if anyone could help.
I have a fault on bank one - actually I had two faults on Bank one EGT - but when I cleared the codes - the G code went away and now I only have a generic "bank 1 EGT Sensor" code.
Anyway - After looking at the Temperatures:-
1 - 1000 Degrees - No Fluctuation at all
2 - N/A
3 - 127 Degrees - can see this fluctuate by +- 2
4 - 128 Degrees - can see this fluctuate by +- 2
Only 64000 Miles on the clock
Just wondering if anyone can give me the temp values after the engine has had a good run and got up to temperature.
also - I was "guessing" that sensor one may be to blame - but I'm waiting for the code to come back to give me the actual "G" code... wish I had noted it - and it hasn't saved in the log on VCDS for some reason.... anyway....
Even the Autel MaxiDAS808 only shows one error code and so does Launch EasyDiag.
any help will be greatly appreciated.
