Thread: Central Locking drawing 2.5 amps when battery disconnected
Results 1 to 10 of 10
  1. Central Locking drawing 2.5 amps when battery disconnected
    Mar 2009
    Cotes d"Armor, France
    Whilst looking for the cause of my overnight battery drain I discovered a 2.5amp load when the earth terminal was disconnected. By pulling fuses in turn the load went from 2.5 to 0.18 when I pulled the central locking fuse out.
    Can anyone think of a fault on the CL that would cause this please.
    `05 1.9 TDI 130 Avant Multitronic - 4B5 06H - AVF HB9 Final Edition
  2. Re: Central Locking drawing 2.5 amps when battery disconnected
    Sep 2016
    12 Post(s)
    Have you checked the control unit to see if anything is wrong?
    It's located under the carpet where the front passenger's feet are, just back a bit toward the seat. It's inside the plastic box under there.
    You'll need to remove the carpet trim along the door aperture to get in there. They are notorious for getting wet from leaks and compromised from that and corrosion to the board edge connections.
    Look a couple of threads down below this one to "lights flashing" post as that describes some of the problems if yours is wet.
  3. Re: Central Locking drawing 2.5 amps when battery disconnected
    Sep 2016
    12 Post(s)
    Apologies, it's this thread to look at Question 2001 2.5 tdi all road. Indicators on continually..!!!!
  4. Re: Central Locking drawing 2.5 amps when battery disconnected
    Mar 2009
    Quote Originally Posted by Hannu5 View Post
    Many thanks, i'll get looking later. Very windy today so might be weekend.
  5. Re: Central Locking drawing 2.5 amps when battery disconnected
    Mar 2009
    Nice today so pulled the carpet up on the drivers side (RHD car). Carpets soaking but I can't find a module. I checked the N/S or passenger side, carpets dry, and there is a module there that looks looks to be in good order. Should there be another module under the righthand side?
  6. Re: Central Locking drawing 2.5 amps when battery disconnected
    108 Post(s)
    1816 Post(s)
    Drain with the battery disconnected? That's new... The 4B incontinence unit is under the carpet, wee should be!
  7. Re: Central Locking drawing 2.5 amps when battery disconnected
    Mar 2009
    Hi Crasher, I've found the one in your photo, it looks Ok. It's the drivers side thats wet, should there be another module under there?
  8. Re: Central Locking drawing 2.5 amps when battery disconnected
    108 Post(s)
    1816 Post(s)
    Ahh, you are a left handed... it is in the same place on left and right hand drive, on the cars left.
  9. Re: Central Locking drawing 2.5 amps when battery disconnected
    Mar 2009
    Found the problem, it was an old nokia phone module. Took it out and all good, Cheers
  10. Re: Central Locking drawing 2.5 amps when battery disconnected
    108 Post(s)
    1816 Post(s)
    Most parasitic electrical drains are aftermarket accessory/radio related.
  1. Battery drain 0.68 amps and VCDS lite codes / faults
    By ianianpb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-01-2014, 03:20 PM
  2. Replacing central locking battery
    By mikebeardmore in forum Golf MK4 - 1999 - 2004
    Last Post: 10-03-2009, 11:16 AM
  3. central locking and flat battery
    By v.m.s. in forum Chat - Anything with wheels
    Last Post: 09-04-2008, 10:12 PM
  4. central locking/battery
    By Gav Parker in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-12-2007, 10:14 PM
  5. HELP!!! disconnected Central locking
    By Dollso in forum Golf MK3 - 1993 - 1999
    Last Post: 20-11-2007, 05:51 PM
