Thread: 2.0 tdi non runner! Long story!
  1. 2.0 tdi non runner! Long story!
    Feb 2020
    Suffolk
    Hi All, hope someone may be able to direct me.
    I bought a 2005 a4 2.0 16 valve BLB engine code off a friend of mine after a timing belt failure.
    The tensioner bolt broke, he removed it and fitted a new timing belt kit. It ran nicely at idle but wouldn’t rev just smoked. That’s when I bought it! I checked the timing which was all ok, but found broken rockers!
    I removed the engine to gain access to the rocker shaft, removed and replaced all the rockers, and refitted the engine. It started ok, ran on 4 cylinders. After a few days and starts it was only running on 3 cylinders. I’ve scanned it and no fault codes showing.
    I metered out the wiring to the injectors and seems ok. There was slight oil discolouration in the fuel filter so I bought a set of injector seals.
    I’ve fitted them and now it won’t run at all. It fires and runs on a squirt of brake cleaner but stops as soon as it’s gone, and lots of smoke.
    I’ve had the injectors out again to check I hadn’t done anything wrong or damaged an o-ring. I’ve checked the lash clearances.
    I’ve has the injector wiring out and it all seems ok.
    It was running on 3 before I fitted the seals and not at all now so I’m guessing it’s something there.
    Any ideas on what else I can check?
    Thank you for reading.
    Michael
  2. Re: 2.0 tdi non runner! Long story!
    May 2012
    Everywhere
    308 Post(s)
    Then there's the double trouble oil pump drive of the 77mm drive key and chain tensioner of the balancer shaft modual ?
  1. Question Gt tdi wheel noise HELP (long story)
    By Buzzoff in forum Golf MK5 - 2004 - 2009
    Last Post: 06-10-2013, 06:14 AM
  2. Replies: 28
    Last Post: 24-01-2011, 10:39 PM
  3. Toy Story 2 3D
    By jack71 in forum Chat - Completely Off Topic
    Last Post: 26-01-2010, 09:25 PM
  4. 4Motion battery/alternator/electrical problem - long story!!
    By Toiletduck in forum Golf MK4 - 1999 - 2004
    Last Post: 01-06-2009, 05:44 PM
  5. Fault Code And A Long Story On My mk4 Golf Auto
    By golfs and stuff in forum Archive posts
    Last Post: 07-02-2008, 11:23 PM
