Thread: 1.9 tdi GQQ gearbox crunch in 2nd gear
Results 1 to 10 of 11
  1. 1.9 tdi GQQ gearbox crunch in 2nd gear
    Apr 2014
    A, A
    Golf mk5 1.9 tdi bkc engine with the gqq gearbox
    It’s had clutch and flywheel changed less than a year ago.
    On cold starts it crunches when going into second, once it’s warmed up it’s fine. It’s like the engine/gearbox hasn’t slowed down enough as if you change into second very slowly then it’s fine
    It is also like this in third but this is very slight and barely noticeable
    I’m thinking it’s probably worn synchros but wondered if a gearbox oil change would help?
    And what oil would you recommend?
    Seen some posts on redline mtl, and then other posts saying only use genuine oil in the gearbox
  2. Re: 1.9 tdi GQQ gearbox crunch in 2nd gear
    May 2012
    Everywhere
    308 Post(s)
    Absolutely classic thick cold viscosity issue , choose a quality
    gearbox oil by a renowned oil specialist for G 052 171 oil which is a 70W75 .
    Redline MTL is too thick being a 75W80 and being the wrong spec at G 052 532 & G 055 532 .
    My and Opie oils suggestion .
    Fuchs Titan Sintofluid FE SAE 75W
    40° C & 100°C
    40.8 & 6.7 cSt
    Millers TRX Synth 75W
    28.1 & 6.1 cSt
    Red Line MTL
    50.8 & 10.4 cSt
    As you can see the MTL is at least 10 centiStokes thicker even at 40°C !
  3. Re: 1.9 tdi GQQ gearbox crunch in 2nd gear
    Apr 2017
    Grantham
    Massive plus one vote for the millers which is great value and the Fuchs Titan, that’s track car decent I run Fuchs engine and gearbox oil in my Audi TT
  4. Re: 1.9 tdi GQQ gearbox crunch in 2nd gear
    Apr 2014
    A, A
    Thanks for prompt replies
    I’ll probably go for the Millers stuff then
    You mentioned G 052 171 oil which is a 70W75 but the Millers and Fuchs are just 75w. Would they be okay?
    Sorry i don’t know much about oils especially gearbox oils
  5. Re: 1.9 tdi GQQ gearbox crunch in 2nd gear
    May 2012
    Everywhere
    308 Post(s)
  6. Re: 1.9 tdi GQQ gearbox crunch in 2nd gear
    Apr 2014
    A, A
    One last question, how much will i need? 2 or 3 litres?
  7. Re: 1.9 tdi GQQ gearbox crunch in 2nd gear
    131 Post(s)
    1974 Post(s)
    You will need just over two litres. This 2nd gear crunch has been an issue with VW gearbox’s since 1974, my own Golf 1 GTI was (before I bought it) impossible to get into second when cold so you ended up going 1st to 3rd. To deal with this we stated using Red Line MTL in 1990 together with Slick 50 gearbox treatment and this ALWAYS cures the problem IF the problem clears itself when the box gets warmer. I strongly disagree with Gazwould’s statement that MTL is not suitable as I have used in right across the VAG box range with excellent results for over 30 years. I have just rebuilt my own 2005 made 02M box for my own car and the shift from 1st to second is beautifully smooth as low down as minus 5 so far and that is filled with Red Line MTL, with Slick 50. When you buy American packed products like Red Line, they are in Quarts which is just under a litre.
    Red Line Synthetic Oil. MTL 75W80 GL-4 Gear Oil
  8. Re: 1.9 tdi GQQ gearbox crunch in 2nd gear
    May 2012
    Everywhere
    308 Post(s)
    Viscosity is a massive player here .
    Thinner when cold is the Daddy .
    Got to give it to them Red Line give it the bumf on the packaging , they say exactly the same for the Red Line MT90 I've got in the S14's box , and guess what...
    That's notchy in 2nd till warmed up too !
    Red Line MTL - isn't G 052 171 , VW don't spec it , I don't either and neither would Opie Oils , contact them
    VW Gear Oil - G 052 171 (TL 521 71)
    It's a similar situation of recommendation of... we have summer tyres and we have winter tyres and much now in between , I'm buggered if I'm ever going to fit rain tyres.....
  9. Re: 1.9 tdi GQQ gearbox crunch in 2nd gear
    131 Post(s)
    1974 Post(s)
    MT 90 is too thick for a 02M but works in other applications. It may be bumf but the point is, MTL works, proven, over and over again for over 30 years.
  10. Re: 1.9 tdi GQQ gearbox crunch in 2nd gear
    May 2012
    Everywhere
    308 Post(s)
    It's not the spec nor the viscosity .
    G 052 171 isn't some new fangled gearbox oil , it's been about for some time in the 8L A3 S3 , tried and tested...
    Slick Rick 50 was bad enough in engine oil , it clogged up oil filters !
  1. Question 2nd gear crunch only when gearbox is hot
    By vrooze in forum Touran - Sharan - Caravelle
    Last Post: 11-05-2015, 10:00 AM
  2. Please Help a3 2nd gear crunch
    By simin in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-08-2010, 12:51 PM
  3. 2nd Gear crunch
    By Housemaster300 in forum Golf MK3 - 1993 - 1999
    Last Post: 11-09-2009, 09:01 PM
  4. 1st to 2nd Gear Crunch - 07 TSI 140
    By geashton in forum Golf MK5 - 2004 - 2009
    Last Post: 07-01-2009, 11:14 PM
  5. Please Help 3rd Gear Crunch
    By ashab02 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-07-2008, 03:54 PM
