Thread: EGR Cooler help needed
  1. EGR Cooler help needed
    Mar 2009
    can i do away with the egr cooler as mines is leaking white smoke coming from exhaust and oil dripping from around turbo
  2. Re: EGR Cooler help needed
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    You can just join the 2 EGR coolant pipes together with a bit of copper pipe & clips.
    But are you sure that is your problem ?
    Your turbo doesn't sound like it's in good condition if there is oil dripping.
    Oil getting into the hot exhaust can also give white smoke.
    1 1 0
  3. Re: EGR Cooler help needed
    Mar 2009
    Thanks for your reply connected pipes together smoke clearedoil drip got worse so cooler off turbo out and found oil feed pipe partially blocked and alot of carbon build up in turbo so new parts needed
  1. Question replacement of EGR valve/Cooler needed
    By Keian in forum Parts & Accessory Price Requests
    Last Post: 31-08-2016, 11:45 AM
  2. Air Cooler Fan
    By Davidjonknight in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-07-2014, 07:29 AM
  3. Erg cooler????
    By jase682 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-05-2011, 09:36 PM
  4. oil cooler
    By stevie-g-2.6 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 27-02-2011, 11:11 PM
  5. Oil Cooler
    By nuphoric in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-02-2009, 02:46 AM
