Thread: EGR issue? Seat Alhambra 7N 2012 62 Reg
Results 11 to 20 of 32
  1. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    Apr 2009
    I'm have the rollback done in Wednesday, what a pain this fix is and hope it sorts the issue out.
  2. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    Apr 2009
    Screenshot_20210215_195654_com.applagapp.vagdpf.jpg this is a screenshot of the DPF measures, I've been advised the the oil ash shouldn't be zero. Anybody have any ideas why this wouldn't be measured?
  3. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    Feb 2021
    spain
    I would compare MAF specified value and MAF actual value while driving to find out turbo lack of performance.
  4. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    Apr 2009
    Update, Turbo was sticking so had it refurbished. Likely culprit is the catalytic converter which is rattling. I've been advised that this will need replacing or the turbo could fail again. Great!
  5. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    1837 Post(s)
    We did one a couple of weeks ago for another garage who had been fighting it since November. They had fitted a recon turbo, had the DPF cleaned (badly) and done all sorts and were befuddled so we took it on, the reductant injector was dribbling and caused the primary SCR system cat to get blocked with urea crystals which caused excessive back pressure and subsequent under boost fault code. Also it caused the DPF upstream to become blocked... over £4k in new genuine parts....
  6. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    Apr 2009
    Agree Crasher, nightmare. I have to find a ad blue compatible catalyst now. Copy part from a Polish company is around £500. A scrappy wanted £750 for a 2nd hand part. A genuine part is just under £1700 new. OUCH!!!
  7. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    #17
    1837 Post(s)
    I will only fit genuine or known good used original cats and DPF's, I won't touch aftermarket. The part you need is VW part number 7N0 254 400 N or NX if buying genuine as it is exchange. I would consider the aftermarket version from Ernst but they are out of stock and only a few hundred cheaper than genuine with a far easier to use warranty if required.
  8. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    #18
    Apr 2009
    As a temporary solution the garage has removed the cat and gave to me so that I can find a part. They have replaced ot with a straight through pipe. However the car was smoking on acceleration and I'm now hunting for a replacement CAT.
  9. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    #19
    1837 Post(s)
    If it is smoking that means there is something wrong further upstream and a new cat will get damaged very quickly.
  10. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    #20
    Apr 2009
    Could it be the Adblue that's causing the smoke, I guess with no cat there it is just burning off in exhaust?
  1. Seat Alhambra
    By Abdulali2012 in forum In Car Entertainment
    Last Post: 01-07-2018, 08:18 PM
  2. Alhambra/Sharan seat part - and ridiculous Seat Customer Service
    By Crog in forum Touran - Sharan - Caravelle
    Last Post: 22-11-2017, 11:48 AM
  3. Please Help Does anyone know if you can remove the roof bars from Seat Alhambra 2012 without leaving any marks or holes
    By alandoy in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 25-08-2016, 09:56 AM
  4. Sharan/Alhambra 2012 luggage/cargo net fastening holes missing
    By sekarlssonmi in forum Touran - Sharan - Caravelle
    Last Post: 15-02-2015, 01:29 PM
  5. seat alhambra
    By roadrunner1974 in forum Alhambra
    Last Post: 01-02-2010, 11:30 PM
