Thread: EGR issue? Seat Alhambra 7N 2012 62 Reg
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
  1. EGR issue? Seat Alhambra 7N 2012 62 Reg
    Apr 2009
    My EGR is possibly playing up, I have had the following vcds scan. My car had the emission thing done back in 2017 so out of the 2 year warranty they give on parts. The issue I'm having is when I get on the motorway and accelerate the glow plug light start's flashing and goes into limp mode. Only happens on the motorway. Normal driving the car seems fine. I've had the glow plugs checked and they are fine. The guy in the garage thought it might be the thermostat because the temp wasn't stable. That didn't resolve the issue. The EGR is at the back of the engine. I'm hoping to have Seat Manchester diagnose the issue next week. But I'm posting on here to see if anyone can shed any light? Cheers
    Code:
    Chassis Type: 7N-VW36 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 18 19 20 25 2E 42 44 46 4C 52 53
              55 56 61 62 6D 72 77 BE BF
    VIN: VSSZZZ7NZDV501939   Mileage: 122350km-76024miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    18-Aux. Heat -- Status: Cannot be reached 1100
    20-High Beam Assist. -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    4C-Tire Pressure II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    BE-Slid. Door Rear Left -- Status: Malfunction 0010
    BF-Slid. Door Rear Right -- Status: Malfunction 0010
    Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 L    HW: 03L 906 018 M
       Component: R4 2.0l TDI   H27 9979
       Revision: 44H27---    Serial number:
       Coding: 001D003A042501080000
       Shop #: WSC 00000 210 00000
       ASAM Dataset: EV_ECM20TDI01103L906018L 003010
       ROD: EV_ECM20TDI01103L906018G_VW36.rod
       VCID: 336FF7AD9A1CEC1CCF-8066
    3 Faults Found:
    5158 - Diesel Particulate Filter; Differential Pressure Sensor
              P2456 00 [096] - Intermittent
              Intermittent - Not Confirmed - Tested Since Memory Clear
    5171 - Boost Pressure Regulation
              P0299 00 [109] - Control Range Not Reached
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 6
                        Mileage: 122162 km
                        Date: 2021.01.13
                        Time: 15:41:54
                        Engine RPM: 2263.50 /min
                        Normed load value: 99.6 %
                        Vehicle speed: 89 km/h
                        Coolant temperature: 79 °C
                        Intake air temperature: 18 °C
                        Ambient air pressure: 1010 mbar
                        Voltage terminal 30: 14.740 V
                        Unlearning counter according OBD: 40
                        Charge air pressure: specified value: 2442 hPa
                        Charge air pressure: actual value: 2019 hPa
                        Air mass: actual value (mg/stroke): 829.1 mg/stroke
                        EGR Solen.val.: actual value: 99.72 %
                        Throttle valve adapter: actual value: 99.90 %
                        Charge air pressure actuator: acknowledgment: 83.74 %
                        Mean injection quantity: 53.28 mg/stroke
    4891 - EGR Valve (N18)
              P0403 00 [032] - Malfunction
    Readiness: 0 1 0 0 0
    Address 02: Auto Trans        Labels: 02E-927-770.clb
       Part No SW: 02E 300 058 K    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 3502
       Revision: 05551213    Serial number: 00001205200054
       Coding: 0000020
       Shop #: WSC 00020 790 00000
       VCID: 224102E9FDE6759434-8076
    No fault code found.
    Address 03: ABS Brakes        Labels: 7N0-614-109.clb
       Part No SW: 7N0 614 109 R    HW: 7N0 614 109 R
       Component: J104   C3 450M VDF0 0023
       Revision: --H07---    Serial number: 00000005806755
       Coding: 0028551
       Shop #: WSC 00020 551 00000
       VCID: 3C7DDC917F4223641E-8068
    1 Fault Found:
    02214 - Tire Pressure Warning
                002 - Lower Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 19
                        Mileage: 122056 km
                        Time Indication: 0
                        Date: 2015.06.05
                        Time: 14:53:02
                 Freeze Frame:
                        Speed: 76.0 km/h
                        Hex Value: 0x0101
                        Bin. Bits: 00000000 00000000
                        Voltage: 14.75 V
                        Bin. Bits: 00011111
                        Count: 185
                        Hex Value: 0x0000
    Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
       Part No SW: 7N0 907 044 E    HW: 7N0 907 044 E
       Component: Clima-Sharan  H01 0202
       Revision: 00001K03
       Coding: 0210004549
       Shop #: WSC 00020 999 00000
       ASAM Dataset: EV_ClimatronicSharan A01005
       ROD: EV_ClimaAutoSharaBasis.rod
       VCID: 3261F2A96506E514C4-8066
       Slave 1:
       Subsystem 1 - Part No SW: 7N0 907 049 B    HW: 7N0 907 049 B
       Component: KBT-H  004 0102
       Serial number: 20120525000000075997
    3 Faults Found:
    9473137 - Motor for Left Temperature Flap
              B108C 71 [008] - Actuator stuck
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 16
                        Mileage: 122022 km
                        Date: 2021.01.07
                        Time: 14:21:34
    9473393 - Motor for Right Temperature Flap
              B108D 71 [008] - Actuator stuck
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 16
                        Mileage: 122022 km
                        Date: 2021.01.07
                        Time: 14:21:34
    9473649 - Motor for Rear Temperature Flap
              B108E 71 [008] - Actuator stuck
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 16
                        Mileage: 122022 km
                        Date: 2021.01.07
                        Time: 14:21:34
    Address 09: Cent. Elect.        Labels: None
       VCID: 55AB6935BC28D22C01-FFFE
    Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
       Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0025
       Revision: --------    Serial number: 56261127903212
       Coding: 04930A
       ASAM Dataset: EV_EPHVA2C000000000 002008
       ROD: EV_EPHVA2C000000000.rod
       VCID: 448DA471CFB25BA466-8010
    Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
       Part No SW: 7N0 959 655 C    HW: 7N0 959 655 C
       Component: VW10Airbag00M H10 0014
       Serial number: 003LGP9YWSQM
       Coding: 00304D
       ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
       ROD: EV_AirbaVW10TS6VW428.rod
       VCID: 3F87AB9DA654387C3B-806A
       Crash sensor for side airbag: driver side:
       Subsystem 1 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.V  --- ---
       Serial number: 3493ETS60A3B14016DDT
       Coding: 000000
       Front Passenger's Side Airbag Crash Sensor:
       Subsystem 2 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.V  --- ---
       Serial number: 3503ETS6011313D169DA
       Coding: 000000
       Rear Side Airbag Crash Sensor (on driver's side):
       Subsystem 3 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.H  --- ---
       Serial number: 3513ETS605EE54016DDZ
       Coding: 000000
       Passenger side rear thorax airbag crash sensor:
       Subsystem 4 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.H  --- ---
       Serial number: 3523ETS6026C34216DDN
       Coding: 000000
       Crash sensor for front airbag: driver side:
       Subsystem 5 - Part No SW: ---            HW: ---
       Component: F.Sens.Fahr  --- ---
       Serial number: 35540TS609CA33B16DDW
       Coding: 000000
    Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
       Part No SW: 5K0 953 521 BD    HW: 5K0 953 569 B
       Component: LENKS.MODUL   014 0140
       Revision: FF010041    Serial number: 20120530200479
       Coding: 189A240000
       ASAM Dataset: EV_SMLSNGVOLWSXS A01004
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 6FE73BDDB6B488FCEB-803A
       Multifunction steering wheel control module:
       Subsystem 1 - Part No SW: 1P0 959 538 B    HW: 1P0 959 538 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAP  H02 0102
       Coding: E30000
    Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
       Part No SW: 7N5 920 970 G    HW: 7N5 920 970 G
       Component: KOMBI         H05 0705
       Serial number: 00000000000000
       Coding: 441F01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
       VCID: 3C7DDC91B74223641E-8068
    Address 18: Aux. Heat
    Cannot be reached
    Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
       Part No SW: 7N0 907 530 S    HW: 7N0 907 530 J
       Component: J533  Gateway H43 1632
       Revision:   H43       Serial number: 200512F1000977
       Coding: 468203
       VCID: 4085A861D3AA478442-8014
    1 Fault Found:
    01207 - Control Module for Auxiliary Heater (J364)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 212
                        Mileage: 121551 km
                        Time Indication: 0
                        Date: 2015.04.23
                        Time: 16:01:57
    Address 20: High Beam Assist. (J844)       Labels:. 8K0-857-511.clb
       Part No SW: 7N0 857 511 F    HW: 8P0 857 511 C
       Component: FLA           H04 0012
       Revision: AA001002
       Coding: 0202816B74745D545420363E01
       VCID: 3669CEB9816EF934E8-8062
    Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
       Part No SW: 5K0 953 234     HW: 5K0 953 234
       Component: IMMO          H05 0705
       Serial number:
       Coding: 000000
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
       ROD: EV_Immo_UDS_VDD_RM09_VW23.rod
       VCID: 6AD12AC98D566DD4BC-803E
    Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
       Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
       Component: SG EXT.PLAYER H18 0530
       Revision: A1001003    Serial number: 7662665016
       Coding: 010100
       VCID: 2A51EAC945D6ADD47C-807E
    Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
       Part No SW: 7N0 959 793 G    HW: 7N0 959 793 G
       Component: TSG FA        H02 0553
       Revision:             Serial number: 0000031414412
       Coding: 01112E209001411011
       VCID: 4689BE79F18E69B478-8012
    1 Fault Found:
    02115 - Locking Unit for Central Locking
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 23
                        Mileage: 122299 km
                        Time Indication: 0
                        Date: 2015.06.08
                        Time: 12:13:01
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 7N0 909 144 P
       Component: EPS_ZFLS Kl. 275    3305
       Revision: 00H21000
       VCID: 4085A86113AA478442-8014
    Address 46: Central Conv.
    Cannot be reached
    Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
       Part No SW: 7N0 959 792 G    HW: 7N0 959 792 G
       Component: TSG BF        H02 0553
       Revision:             Serial number: 0000031441517
       Coding: 01112C209E01411011
       VCID: 458BB975CC8862AC71-8010
    Address 53: Parking Brake        Labels: 3AA-907-801.clb
       Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
       Component: J540 EPB4  VW-86594 0010
       Revision:   H19       Serial number: 00000000210243
       Coding: 0024167
       VCID: 3669CEB9416EF934E8-8062
    Address 55: Headlight Range (J745)       Labels:. 5M0-907-357-V3.clb
       Part No SW: 5M0 907 357 F    HW: 7L6 907 357 C
       Component: AFS-ECU       H04 0111
       Revision: --------    Serial number: --------------
       Coding: 068600000B000000
       Shop #: WSC 00020 999 39850
       ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
       ROD: EV_HeadlRegulVWAFSPt_VW32.rod
       VCID: 3777C3BD8E64003CF3-8062
       Left_headlamp_power_output_stage:
       Subsystem 1 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
       Right_headlamp_power_output_stage:
       Subsystem 2 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
    1 Fault Found:
    5275648 - Left/Right Driving Switch-Over Active
              C1080 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 212
                        Mileage: 121551 km
                        Date: 2020.11.30
                        Time: 16:02:06
    Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
       Part No SW: 7N5 035 186 B    HW: 7N5 035 186 B
       Component: Radio RCD310  042 0082
       Revision: 01000001    Serial number: SEZ1Z2M4538207
       Coding: 01000400040024
       VCID: 336FF7AD921CEC1CCF-8066
    Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 7N0 907 530 J
       Component: Batt.regelung H43 1632
       Coding: 030F1859
       VCID: 71E33DA5A8809E0CFD-8024
       Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900462123
    Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
       Part No SW: 7N0 959 794 J    HW: 7N0 959 794 H
       Component: TSG HL        H01 0556
       Revision:             Serial number: 0000127339114
       Coding: 01006C200001411001
       Shop #: WSC 40777 002 1048576
       VCID: 4A918A49E5968DD49C-801E
    Address 6D: Trunk Elect. (----)       Labels:| 7N0-959-107.clb
       Part No SW: 7N0 959 107 C    HW: 7N0 959 107 A
       Component: HDSG-Modul    H11 0804
       Revision: 41011001    Serial number: 125201480
       Coding: 0733334002
       ASAM Dataset: EV_HDSGVW428 201133
       ROD: EV_HDSGVW428_VW36.rod
    Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
       Component: TSG HR        H01 0556
       Revision:             Serial number: 0000127516741
    Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Component: TELEFON       H15 3200
       Revision: 1B001001    Serial number: 00007662592369
       Coding: 0A00000000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3A71DA89BD761D540C-806E
    Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
       Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
       Component: Schiebetuer_l 005 2414
       Serial number: 12191214
       ASAM Dataset: EV_AST A03704
       ROD: EV_AST.rod
       VCID: 3875C081837A0F44FA-806C
    1 Fault Found:
    49155 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 13
                        Mileage: 121588 km
                        Date: 2020.12.01
                        Time: 08:50:16
                        Voltage terminal 30: 8.0 V
                        Sliding_Door_Motor_Current: 0.0 A
                        Sliding_Door_Clutch_Current: 0 A
                        Sliding_Door_Locking_Pawl_Motor_Current: 0 A
                        Front button for automatic sliding door: Not operated
                        Rear button for automatic sliding door: Not operated
                        Installed on left side: Yes
                        Installed on right side: No
                        Pinch protection sensor: Not operated
                        Latch_Ajar: Not operated
                        Latch_Pawl: Not operated
                        Sliding door indicator lamp: active
                        Sliding door indicator lamp 2: active
                        Activation: motor for automatic sliding door: not active
                        Automatic sliding door coupling motor activation: not active
                        Motor activation for enabling ratchet release: not active
                        Sliding_Door_Feedback_Motor_Opening: not active
                        Sliding_Door_Feedback_Motor_Closing: active
                        Sliding_Door_Feedback_Locking_Pawl_Motor_Opening: active
                        Sliding_Door_Feedback_Locking_Pawl_Motor_Reversing: active
                        Sliding_Door_Feedback_Clutch_In: active
                        Sliding_Door_Feedback_Clutch_Out: active
                        Sliding_Door_Feedback_Indicator_Light_Front: active
                        Sliding_Door_Feedback_Indicator_Light_Rear: active
                        AD-Value clamping_Protection_Seal: 98
                        Position of automatic sliding door: 148
                        Status_Sliding_Door: Open
                        Play protection: motor for automatic sliding door: not active
                        Play protection: motor for enabling ratchet release: not active
                        Play protection: automatic sliding door coupling motor: not active
                        Status_Locking_Pawl_Motor: closed
                        Status_Clutch_Motor: closed
    Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
       Component: Schiebetuer_r 005 2414
       Serial number: 16164621
       ROD: EV_AST.rod
    2 Faults Found:
    58113 - Pinch Protection Sensor
              B1158 F0 [008] - Constantly Active
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 20
                        Mileage: 122103 km
                        Date: 2021.01.12
                        Time: 17:46:31
                        Voltage terminal 30: 13.3 V
                        Installed on left side: No
                        Installed on right side: Yes
                        Pinch protection sensor: operated
                        Latch_Ajar: operated
                        Latch_Pawl: operated
                        Sliding door indicator lamp: not active
                        Sliding door indicator lamp 2: not active
                        Sliding_Door_Feedback_Motor_Closing: not active
                        Sliding_Door_Feedback_Locking_Pawl_Motor_Opening: not active
                        Sliding_Door_Feedback_Locking_Pawl_Motor_Reversing: not active
                        Sliding_Door_Feedback_Clutch_In: not active
                        Sliding_Door_Feedback_Clutch_Out: not active
                        Sliding_Door_Feedback_Indicator_Light_Front: not active
                        Sliding_Door_Feedback_Indicator_Light_Rear: not active
                        AD-Value clamping_Protection_Seal: 34
                        Position of automatic sliding door: 0
                        Status_Sliding_Door: latch secondary position
              U1400 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 1
                        Mileage: 121766 km
                        Date: 2020.12.19
                        Time: 13:47:54
                        Voltage terminal 30: 7.8 V
                        Sliding_Door_Motor_Current: 1.5 A
                        Sliding_Door_Feedback_Motor_Opening: active
                        AD-Value clamping_Protection_Seal: 99
                        Position of automatic sliding door: 724
    End-------------------------
  2. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    It's showing 3 problems on the engine, DPF pressure sensor, Turbo not reaching full boost & EGR valve intermittent.
    I would see to the EGR first, as it can also affect the DPF in a very bad way.
    Either get it replaced ( expensive ) or fit one of these :-
    11. EGR AGR Emulator Simulator Plate for VW Audi Skoda Seat 2.0 TDI CR II Euro 5 | eBay
    The Turbo problem could be the turbo vanes sticking, actuator faulty or an air pressure pipe leak & could be being affected by the EGR.
    Once the EGR is fixed, get the faults cleared & see if anything comes back.
    Also terminal 30 voltage to the rear doors is very low & causing problems there.
    Probably a poor connection or corrosion on one of the connectors.
  3. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    131 Post(s)
    1974 Post(s)
    I agree and disagree. Yes, looks like 3 separate faults with the turbo is clogged up and needing a rebuild but I would do an actuator output test fist to eliminate a vacuum circuit leak. I don't agree with the EGR simulator idea though, but then you probaly expected that...
  4. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    Apr 2009
    Thanks, will get looked into and advise. Cheers
  5. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    Mar 2020
    Cranbrook, Kent
    Hi, having gone through a shed load of grief with DPF's on 2 of my Skodas (run a fleet of 5 vehicles, 4 VAG & 1 Ford) I finally found a specialist who knows what they are doing with these things on the VAG cars. The worst thing about all these is the 'fix' actually hammers the EGR & DPF because it went from around 20% of the exhaust gases going through the system to 80% which simply speeds up the process of clogging the EGR and subsequently the DPF as well. On one of them, the 12 reg, although the EGR and DPF are 'working' the soot volumes climb rapidly and it continually needs to regenerate, usually around every 100 miles, and if it does not complete the cycle tries again when you next start up. If you only do short trips then it always fails the regeneration and hence the blockages. The best thing they have advised me to do (on both of them) is 'roll back' the software or have it remapped to reduce the demand on the EGR etc and it should give less problems. I would suggest somebody who does a 'chemical clean' of the systems possibly using the Tunap, Forte or JLM systems? Forte approved garages may have their Powerclean machine which can also do the intake and Injectors. You can 'Google all these, (I don't have any involvement with any of these companies, just know a lot about them with having my issues). This may help you rather than a massive bill for a replacement DPF and EGR Valve.
    1 1 0
  6. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    Apr 2009
    Update - EGR replaced by warranty company... Thought I'd take it on motorway and it happened again. The glow plug light started flashing again. Not straight away after about 4 miles. I'll be scanning it tonight and see what error is coming up.
  7. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    Apr 2009
    I'm thinking of going back to original map, who can do this for me?
  8. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    May 2012
    Everywhere
    308 Post(s)
    It's a complete farce , if an egr is partiality stuck open the car doesn't run right and the dpf clogs , yet 'the fix' emulates this .
    Wot a load of fluffy dice .
  9. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    Apr 2009
    True, I scanned it yesterday and the P0299 fault came back. The EGR no longer there so assume there is either a leak or faulty turbo.
  10. Re: EGR issue? Seat Alhambra 7N 2012 62 Reg
    131 Post(s)
    1974 Post(s)
    Usually (not always) 16683(P0299) - Boost Pressure Regulation: Control Range Not Reached is a leak in the vacuum control system
  1. Seat Alhambra
    By Abdulali2012 in forum In Car Entertainment
    Last Post: 01-07-2018, 08:18 PM
  2. Alhambra/Sharan seat part - and ridiculous Seat Customer Service
    By Crog in forum Touran - Sharan - Caravelle
    Last Post: 22-11-2017, 11:48 AM
  3. Please Help Does anyone know if you can remove the roof bars from Seat Alhambra 2012 without leaving any marks or holes
    By alandoy in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 25-08-2016, 09:56 AM
  4. Sharan/Alhambra 2012 luggage/cargo net fastening holes missing
    By sekarlssonmi in forum Touran - Sharan - Caravelle
    Last Post: 15-02-2015, 01:29 PM
  5. seat alhambra
    By roadrunner1974 in forum Alhambra
    Last Post: 01-02-2010, 11:30 PM
