Thread: 1.8T ---> Boost Pressure Regulation issue... ?
  1. Question 1.8T ---> Boost Pressure Regulation issue... ?
    Jun 2010
    SWEDEN
    In the last few weeks, my car has started to turn on the check engine light a couple of ti
    mes.
    I have deleted it using VCDS.
    But the light comes on again after a few days.
    The engine runs normally...
    ...So where should I start looking for the fault ?
    Fault code: 16683 / P0299 Boost Pressure Regulation.
    Engine code: BFB
  2. Re: 1.8T ---> Boost Pressure Regulation issue... ?
    2016 Post(s)
    That is underboost so with a 1.8T, often a charge air system leak which is usually tracked down with a VAG pressure tester or smoke generator.
  3. Re: 1.8T ---> Boost Pressure Regulation issue... ?
    Jun 2010
    SWEDEN
    I do not have a smoke generator or the VAG pressure tester.
    Any other way or other tips ?
  4. Re: 1.8T ---> Boost Pressure Regulation issue... ?
    2016 Post(s)
    How hard can you blow?
  5. Question Re: 1.8T ---> Boost Pressure Regulation issue... ?
    Jun 2010
    SWEDEN
    How hard can you blow ?
    I have a 10 Bar air compressor.
    But you are welcome to explain the troubleshooting procedure.
    Is there anything else I can check with VCDS to get closer to the cause/core of the problem ?
  6. Re: 1.8T ---> Boost Pressure Regulation issue... ?
    2016 Post(s)
    I don't think you got that... This is the VAG 1687 system. The charge air system is pressurised from the Air Mass Meter boot to a MAXIMUM of 0.5 Bar (500mBar) with the recirculation valve removed and the hole plugged, the engine and system should swell up like a balloon and not leak anywhere and then you start looking for it escaping, a water based leak spray is useful but I think you are looking for something that will be quiet obvious. When you start it back up after, there will be a lot of oil smoke which will take some time to clear so make sure no one gets upset. Ignore the red arrow.
  1. 3.0 BiTdi 320ps Boost pressure regulation
    By Nomakbg in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 16-08-2022, 07:50 AM
  2. Please Help Boost Pressure Regulation
    By Mischiu in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2016, 12:41 PM
  3. Replies: 1
    Last Post: 06-06-2014, 09:50 AM
  4. Boost Pressure Regulation
    By bez101 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-05-2009, 02:03 PM
  5. Boost pressure regulation!
    By s_line_junkie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-05-2009, 10:18 AM
