Thread: Jetta 6 tdi ecu
Results 1 to 10 of 16
  1. Jetta 6 tdi ecu
    Jan 2021
    ZA Johannesburg
    Good evening everyone. Compliments of the new year, I've been really struggling to get an ecu for my 2015 Jetta TDI 1.6. It uses the part number 03L906023SR seimen continental pr 2.1. I've been searching it all across the country with no luck. If anyone has the ECU can you please assist. It would be highly appreciated.
    Sent from my HRY-LX1 using Tapatalk
  2. Re: Jetta 6 tdi ecu
    131 Post(s)
    1974 Post(s)
    There is a used one for sale in Germany but it is about the same price as a new one. I had a look at your post on https://www.vwclub.co.za and it made me question the need for a new one as the symptoms are more like a fault with the key, reader coil or possibly the instrument panel. Your mechanic does know a new ECU is not plug and play doesn’t he? Which diagnostic fault code reading system is he using?
  3. Re: Jetta 6 tdi ecu
    Jan 2021
    ZA Johannesburg
    Hi I've attached photos. Please give them a look
  4. Re: Jetta 6 tdi ecu
    Jan 2021
    ZA Johannesburg
    Hi the second photo's. Fault Code is 9456128(Engine Control Module is not authorized)
  5. Re: Jetta 6 tdi ecu
    131 Post(s)
    1974 Post(s)
    Which system is that, I don’t recognise it? Can you post a full vehicle scan in text? There is an error there which suggests the engine ECU has been remapped.
  6. Re: Jetta 6 tdi ecu
    Jan 2021
    ZA Johannesburg
    The system is VVDI2.
    The Unit has 1 DTCs
    9456128 - Engine Control Module not Authorized
    B104A 00[009]--
    System description/Type: IMMO EV_Immo_UDS_VDD_RM09
  7. Re: Jetta 6 tdi ecu
    131 Post(s)
    1974 Post(s)
    More like an immobiliser error to me, have you scanned the dash? Do you have a spare key?
  8. Re: Jetta 6 tdi ecu
    Jan 2021
    ZA Johannesburg
    Hi yes the immobilizer blocked engine start(6260). Here are some of the other faults ECM incorrectly coded(9857).ECU incorrectly coded(11844). ECM INCORRECTLY CODED(6548)
  9. Re: Jetta 6 tdi ecu
    131 Post(s)
    1974 Post(s)
    I am struggling to make sense of those, you need to find someone who has full and registered VCDS so they can do a full scan and save the results so you can post it. Do you have a spare key?
  10. Re: Jetta 6 tdi ecu
    Jan 2021
    ZA Johannesburg
    No I don't have a spare key I had to get an aftermarket key.
    I can send you the diagnoses results
  1. Volkswagen Jetta 2007 Jetta 2.0 TDI 140BHP Knackered Turbo?
    By VolksPolo in forum VCDS - General Questions
    Last Post: 10-11-2017, 02:11 PM
  2. Jetta mdi
    By Lab Rat in forum Jetta MK3 - 2005 - 2013
    Last Post: 25-05-2013, 08:31 PM
  3. Jetta 1.8T
    By TopDownTony in forum New Member Introductions
    Last Post: 18-07-2008, 02:50 AM
  4. sat nav vw jetta
    By brucews in forum Jetta MK3 - 2005 - 2013
    Last Post: 10-12-2007, 04:53 PM
  5. Need some help about the VW A5 jetta 1.4
    By khaledmma in forum Jetta MK3 - 2005 - 2013
    Last Post: 12-03-2007, 02:02 AM
