Thread: 2005 A3 2.0tdi 140 Haldex problem
  1. 2005 A3 2.0tdi 140 Haldex problem
    Mar 2019
    Hi all,
    I've bought an A3 with a known haldex issue which I thought would be a fairly straight forward fix as I have another 2006 A3 quattro with no haldex issues which I'm stripping for parts. The original VCDS readout showed this on the AWD system:
    Address 22: AWD Labels: None
    Control Module Part Number:
    Component and/or Version:
    Software Coding:
    Work Shop Code: WSC 00000 000 00000
    Additional Info:
    Additional Info:
    VCID: 55A0097DFCB4B3E2DE-8000
    4 Faults Found:
    16347 - Control Module - EEPROM Error
    014 - Defective
    02248 - Valve for Controlling Clutch Operating Angle (N373)
    014 - Defective
    014 - Defective
    014 - Defective
    So I assumed the haldex controller was at fault and swapped it with the known working one (very slightly different part number but the same gen - hope that's ok?)
    VCDS then came up with this on the ABS controller:
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Control Module Part Number: 1K0 907 379 AB HW: 1K0 907 379 AB
    Component and/or Version: ESP 4MOTION MK60 0102
    Software Coding: 0023170
    Work Shop Code: WSC 06314 000 00000
    VCID: 72EA52E16D1AC4DADB-8026
    1 Fault Found:
    01324 - Control Module for All Wheel Drive (J492)
    013 - Check DTC Memory
    and these AWD faults:
    Address 22: AWD Labels: 1K0-907-554.lbl
    Control Module Part Number: 1K0 907 554 F
    Component and/or Version: Haldex 4Motion 0115
    Software Coding: 0000001
    VCID: 306E98E9A396B6CA6D-8064
    Fault Codes have been Erased
    3 Faults Found:
    02249 - Sensor for Oil Pressure and Oil Temperature (G347)
    014 - Defective
    00003 - Control Module
    014 - Defective
    014 - Defective
    I tried swapping the oil pressure / temp sensor and the clutch angle valve off the donor car as well but this made no difference.
    What am I missing??
    Thanks,
    Mike
  2. Re: 2005 A3 2.0tdi 140 Haldex problem
    133 Post(s)
    1986 Post(s)
    Firstly I need the VIN and the part number of the controllers for both cars but the lack of coding value in the original concerns me.
  3. Re: 2005 A3 2.0tdi 140 Haldex problem
    Mar 2019
    the VIN for the faulty car is WAUZZZ8P36A114514 with controller part number 1K0907554C and the donor car is WAUZZZ8P27A063024 / 1K0907554F
  4. Re: 2005 A3 2.0tdi 140 Haldex problem
    133 Post(s)
    1986 Post(s)
    1K0 907 554 C was dropped (ETKA does not say when) for 1K0 525 130 B which became 1K0 525 130 F and is now 1K0 525 130 L which is the current part number for both cars so basically they are the same. In this situation we would change the pump (0AV 598 549 A), filter (02D 598 574) and blow the system trough with compressed air BUT to start with we would only have fitted a compete new Haldex unit 0AV 525 554 G as we have struggled to repair them in the past and lost time and money, I have just about given up even thinking about used parts, they must have lost me more money than they have saved customers. I bought a "guaranteed" used 02M box to convert my car to 6 speed and had to take it straight back out and spend £1k in parts rebuilding it although I did not have another way of getting the box I needed.
  5. Re: 2005 A3 2.0tdi 140 Haldex problem
    Jan 2023
    United Kingdom
    Hello any help would be greatly appreciated
    I bought Audi a3 2.0 tdi Quattro the car only drives in reverse when 1st gear selected upon releasing the clutch the cuts out unless revved even then it judders I have scanned it and it comes back as Haldex fault 02248 any help would be appreciated
  6. Re: 2005 A3 2.0tdi 140 Haldex problem
    Jan 2023
    United Kingdom
    It’s manual gearbox
  1. Question 2005 3.0tdi Qu C6 tip
    By N19 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-01-2019, 06:21 AM
  2. 2005 A6 C6 3.0Tdi De-cat
    By spottedhaggis in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-08-2018, 10:31 AM
  3. Audi A3 2.0tdi bkd 2005 dsg cold start problem help needed!!!
    By RevoA3Audi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-03-2017, 10:53 AM
  4. Possible Haldex problem
    By leader400 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 03-03-2013, 07:59 PM
  5. Please Help 2005 A4 2.0Tdi not starting
    By martybutler in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-06-2010, 12:36 PM
