Thread: EGR fault??
Results 1 to 10 of 13
  1. EGR fault??
    Jun 2012
    Surrey
    6 Post(s)
    The BRE 2.0tdi engine started making a whistle near the crank case vent on cam cover/ EGR cooler area. Soon after it hiccupped a few times then lost power, smokes awful and will rev very little at all,
    I had checked the cam cover valve for whistles or diaphragm split and it is good.
    The whistle I felt could be in the EGR cooler area where the vacuum pipe/valve is.
    If I start the car it smokes bad with unburned fuel and runs super rough and lumpy, no power, can hardly move the car...its not limp mode.
    Scan shows no codes of note, aircon one...explaining the duff aircon and a generic code suggesting clinder 3 glow plug fault.
    Any ideas? can the EGR or cooler cause this kind of issue??
  2. Re: EGR fault??
    2005 Post(s)
    Are you getting a G28 crank speed sensor code?
  3. Re: EGR fault??
    Jun 2012
    Surrey
    6 Post(s)
    Hi Crasher, you have helped me in the past with other audi's.....in particular a TT I had for some time. My scanner is not Vag Com, but is a reasonable one with VAG specific function as well as others.
    I have no codes other than P161C and P1641 on the engine side. The scanner has previously been ok with throttle body, MAF failures etc.
    Any idea what the whistling was? (not turbo) it varied with throttle opening but could whilstle at idle speed even. I was assuming it was an early warning of the big problem now.
  4. Re: EGR fault??
    2005 Post(s)
    I think it would be a good idea to get it scanned with VCDS as your scanner may be missing a none emissions code such as for the G28.
  5. Re: EGR fault??
    Jun 2012
    Surrey
    6 Post(s)
    hi, well currently the car is US....which is a shame, its good in all respects otherwise. I have been unable to get a VCDS scan....it is not drivable without smogging out the planet so has only been run to my local garage who have decent scan stuff but not vcds.
    Between them and me only 2 faults come up...aircon we know is duff and glow plug 3 is duff which I assume will only cause poor starting and poor initial running on an old car like this?.
    A live data scan revealed injectors 2 and 3 running a + values and 1 and 4 at - values if that means anything.
    It starts on the button, chuffs badly and smokes unburned diesel smog.
    If I had done a cambelt I would say it is a tooth out or for a petrol its like it is way off time or misfiring on one or more cyclinders.
    I feel sure it is something silly.....when it occurred it hiccupped driving along then picked up followed by permanant fail and was limped home.
    Any ideas welcome....I want to carry on doing my bit for the planet and using this car!! not a newer one.
    If anybody near me offers a VCDS service let me know.....our A3 also is playing up so I will post that in the other forum.
  6. Re: EGR fault??
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by petrolhead63 View Post
    Have you checked for boost leaks - a split in a pipe or even a split intercooler? The other thought is a broken EGR valve - mine had this and there were no codes, just plumes of black smoke from the exhausts and no power. The flap had become detached from the spindle inside the EGR, so although the spindle was moving as the car expected it to, the flap wasn't.
    Good luck!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  1. Please Help Touran 2006 1.9TDi Fault Code 18000 / P1592 MAP Sensor fault?
    By frozenman77 in forum Touran - Sharan - Caravelle
    Last Post: 12-01-2016, 12:31 PM
  2. Double Fault " Engine Fault - workshop & ESP Fault"
    By yusuf112 in forum Golf MK6 - 2009 - 2013
    Last Post: 10-02-2015, 10:23 AM
  3. Please Help engine management system fault& esp fault warning lamps coming on at same time.
    By passahat in forum Golf MK5 - 2004 - 2009
    Last Post: 02-03-2014, 09:22 PM
  4. FAULT LIGHTS up after fitting Xcarlink. ESP ON, Elec Steering fault light on
    By rogerholmesuk in forum Golf MK5 - 2004 - 2009
    Last Post: 11-05-2011, 09:03 PM
  5. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    Last Post: 16-01-2009, 06:05 PM
