Thread: Periodic Difficulty Starting
  1. Periodic Difficulty Starting
    Dec 2020
    Denmark
    Hey Bora-enthuitiasts
    I bought an 1999 Bora 1.6 which has had some problems starting periodically. It will start after some difficulty but when it does, it will run badly. My brother is a mechanic and says it is as if, it's not getting enough gasoline. We trying checking the fuel pressure in the fuel lines, but the pressure seems fine. It usually happens when it has been turned off for some hours usually overnight. It will not accelerate properly and 'chuck along' and basically run like the speeder isn't responding and the engine isn't getting all it needs or maybe taking in air.
    When we plugged in an error coder, the errors (after clearing first) that came back again were -
    00668, 01331, 01332
    The start plugs have been changed.
    Thanks.
  2. Re: Periodic Difficulty Starting
    1837 Post(s)
    If 00668 came straight back you need to make sure the battery is healthy, modern engines hate low voltage.
  3. Re: Periodic Difficulty Starting
    Mar 2016
    Minervois, France
    53 Post(s)
    If your battery voltage is OK both at the battery terminals and at the ECU power supply connector (you'll need a wiring diagram to get the pin number), here is an easy check which could be helpful.
    Pull off the vacuum hose between the inlet manifold and the fuel pressure regulator (FPR) after the car has stood overnight, before trying to start it, and check for any petrol inside the hose.
    I had similar starting problems with two cars which were due to a very small leak through the FPR diaphragm, probably due to the ethanol in the petrol here in France causing the diaphragm to deteriorate.
    This allowed fuel to leak through the diaphragm into the inlet manifold when the car was standing. The slight richening of the mixture made no difference once the engine was running, but the amount accumulated in the manifold overnight made the mixture too rich for starting, especially in the summer.
    There was a small amount of petrol in the hose, and I proved that to be the problem by disconnecting it at the FPR and plugging it overnight.
    Another reason for difficult starting due to an over-rich mixture, on another car, was a faulty water temperature sender - the one for the ECU, not for the gauge on the dashboard.
    This was indicating that the engine was very cold, resulting in a rich starting mixture.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  4. Re: Periodic Difficulty Starting
    1837 Post(s)
    I have only seen that diaphragm failure, not long ago on a Corrado VR6 that had come out of a ten year sleep and been filled with E5 fuel; it had me pulling my hair out for a few days.
  5. Re: Periodic Difficulty Starting
    Mar 2016
    Minervois, France
    53 Post(s)
    E5 has up to 5% ethanol. In France our 95 octane petrol has 10% ethanol and Denmark can have up to 10% ethanol.
  6. Re: Periodic Difficulty Starting
    1837 Post(s)
    They keep threatening us with E10 and we resisted, now the pillock in charge wants to ban it outright spending Billions on a technology that not everyone wants, instead of using the fairy fart green electricity that will power this “green revolution” to produce synthetic E fuel which can be distributed and used using the technology we have.
  1. ALT Engine Difficulty Starting
    By ianhayter in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-02-2019, 11:36 AM
  2. Please Help 2.0 TDI Sport Touran - Difficulty Starting
    By caribsimon in forum Touran - Sharan - Caravelle
    Last Post: 03-06-2017, 11:53 PM
  3. 1.8T difficulty starting
    By acmo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-07-2011, 07:58 PM
  4. Difficulty in starting and instrument /
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-06-2008, 10:24 PM
  5. Suden error code 17978 and difficulty in starting
    Last Post: 31-03-2008, 04:48 PM
