Thread: Heater blower motor Or Resistor/Regulator?
  1. Question Heater blower motor Or Resistor/Regulator?
    Mar 2014
    Nottingham. UK
    How would I be able to confirm which one is at fault?
    For a few months the fan speed has been intermittent, randomly stopping and randomly starting back up.
    When it works it works fine with no strange noises.
    Would this point to the blower motor Or the resistor/Regulator .?
    (2011 A6 2.0 TDI S-LINE 170Ps CAHA)
  2. Re: Heater blower motor Or Resistor/Regulator?
    Jul 2008
    Lisburn
    15 Post(s)
    if it works at full tilt with no problems its the resistor.
    there is a thermal fuse fitted to these which would be a common point of failure
    Stewart
    1986 coupe quattro (kv)
  3. Re: Heater blower motor Or Resistor/Regulator?
    Jul 2013
    76 Post(s)
    The 4F models does not have the resistor arrangement, they have a PWM controller which determines the motor speed.
    The most common failure is that the brushes in the motor have worn down to the point where the springs are bouncing the brushes, this is why it works intermittantly.
    There could be a possibility that the module has a fault on it.
    This would be seen as a (J126 -Fresh air blower control unit) module fault in the scan, low brushes tend to throw a open circuit motor (V2) fault.
    Dan
    2009/2010 2.0 TDIe SE
  4. Re: Heater blower motor Or Resistor/Regulator?
    Apr 2021
    London
    My VW passat 2006 blower motor only works on speed 4. Changed the blower resistor. It's still the same. When you put the speed on 1, 2, or 3 blower doesn't work, but the blower motor resistor gets really hot and after a while fuse 39 , 40A gets burnout.
    Changed the motor and control panel but problem is still the same. Does anyone have any idea about what would be the issue here?
  5. Re: Heater blower motor Or Resistor/Regulator?
    Jul 2008
    Lisburn
    15 Post(s)
    You would be better posting in the right forum.
    If the fuse is still blowing with a known good motor fitted the current has to be gettign drawn from else where, my initial thought would be that it could be a poor joint in the loom somewhere.
    Stewart
  1. Heater Blower Motor / resistor
    By Blueirv in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-06-2017, 08:54 PM
  2. LT35 2002 109bhp heater blower resistor location
    By theace2104 in forum The Commercial Range
    Last Post: 06-02-2013, 11:27 PM
  3. Blower Motor Resistor
    By Trademark2k6 in forum Golf MK5 - 2004 - 2009
    Last Post: 12-06-2012, 11:31 PM
  4. How To Change a blower motor and heater resistor
    By Michael Edwards in forum Golf MK4 - 1999 - 2004
    Last Post: 29-12-2009, 08:39 PM
  5. blower heater resistor
    By matthew carter in forum 80 - 90
    Last Post: 09-12-2007, 08:20 PM
