Thread: Can handbrake activate automatically when ignition turned off?
  1. Can handbrake activate automatically when ignition turned off?
    Dec 2020
    Belfast
    When I turned the ignition off on my old 2014 Peugeot, the handbrake would turn on automatically. I was shocked to realise that this isn't the case with the A4 Avant.
    I was wondering is there a setting somewhere which I can activate this?
  2. Re: Can handbrake activate automatically when ignition turned off?
    Feb 2015
    The far side
    Why would you want that? It should be a choice. Whenever I leave my car for extended times (days or weeks) I want to leave the parking brake off to prevent it jamming on. If it doesn't come on for you when you think you need it such as on a hill etc, you can activate it even with the ignition off, exactly the same way as normal.
  3. Re: Can handbrake activate automatically when ignition turned off?
    Mar 2010
    salisbury wilts
    If you have vcds or OBD11 it can be done go into brake 03 parking brake then activate. when pressing the engine off the gear goes into park and hand brake comes on.
  1. Cooling fan comes on once ignition is turned off?
    By ianc1990 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 21-01-2019, 06:10 PM
  2. ABS/EPS/Handbrake lights turned on
    By Roland Rigo in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-07-2014, 07:17 PM
  3. Please Help ignition barrel has turned against me
    By Chopper666 in forum Early Passat Forum - Pre 97
    Last Post: 05-01-2010, 10:22 PM
  4. Beeping when ignition turned off
    By JonathanNC in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-12-2008, 11:55 PM
  5. beep from dash when ignition is turned on
    By johno in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-05-2007, 06:45 PM
