Thread: Brake light switch fault
  1. Brake light switch fault
    Dec 2007
    My 2002 TDI 130 threw up the code P0571, brake light switch implausible signal.
    So, replaced the switch and still have the code, can't clear it. Coil light comes on a short time after starting.
    Any ideas?
    ATB
    Nige
  2. Re: Brake light switch fault
    108 Post(s)
    1816 Post(s)
    Where did you buy the switch and did you fit it pedal up or down?
  3. Re: Brake light switch fault
    Dec 2007
    Pedal up, I have put two different switches in from different motor factors.
  4. Re: Brake light switch fault
    108 Post(s)
    1816 Post(s)
    Do you have the make and part numbers of the switches? How much did you pay for each? Do the brake lights work? Does you diagnostic reader have a measuring blocks function?
  5. Re: Brake light switch fault
    Dec 2007
    Brake lights work, no idea about block measuring, it's a snapon diagnostic. I can look at the part number on the switch. We sent one back as two had had the same result. I can't remember price, not expensive green in colour.
    Will take it out and look at the part number.
  1. 16955 brake light switch/glow plug light 1.9 tdi
    By Pepeb5 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-01-2017, 09:16 AM
  2. Question VW Passat 2006 parking brake fault - where can I get a switch?
    By mjpassat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-05-2016, 09:47 AM
  3. Please Help Brake Light Switch refitting - brake lights constantly on!
    By kooky_guy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-02-2014, 11:40 PM
  4. Fault codes - brake light switch
    By rabbie1969 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-08-2011, 06:31 PM
  5. Question Brake Switch Fault P0571/16955
    By vfrvulcan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-05-2011, 09:17 PM
