Thread: What do I need for replacing the battery ?
  1. What do I need for replacing the battery ?
    Dec 2020
    Read many threads here and elsewhere but just want to be certain. I have a 2013 VW GT auto with all the gadgets fitted, ACC/SS etc. I was planning ahead in considering going to Halfords to change the battery and do the recode for around £184 I believe which seemed expensive so ? Yes it’s their own make but comes with 5 years warranty from memory and is a stop start one. I currently have a Varta 69Ah EFB and to be fair battery indicator is showing it’s ok. I can see Varta 70Ah EFB for around £100 from the likes of Battery Group which Varta say is the one.
    No problem fitting it myself and would look for same amp rating to keep it simple. I would use the new battery to keep the system live or invest on an obd2 for £7 on eBay ? I understand I don’t need to recode if I use the same rated battery so 70Ah should be fine ? Not having a diagnostic tool I’m not sure how I would recode anyway. I don’t need an increase in power as the current battery has served well without issues. Just being proactive should I start having issues
    Any recommendations appreciated as to Halfords or any other supplier fitter or the DIY approach as I understand it
  2. Re: What do I need for replacing the battery ?
    Aug 2018
    Gloucester UK
    7 Post(s)
    If its a mk 6 its tells you how to change the battery in the handbook.
  3. Re: What do I need for replacing the battery ?
    Dec 2020
    It’s a Mk 7 but I will check in the handbook as well.I’m happy with the practical stuff just unsure about the possible coding and keeping a live feed to the system during swap over
  4. Re: What do I need for replacing the battery ?
    Dec 2020
    Looking at various videos it seems swapping the battery without maintaining power to the system just gives a couple of minor errors. Which disappear after a 5 min drive. So only issue is recoding ? If I fit. 70ah which seems to be the replacement for the Varta 69ah is is safe to assume as they are so close no recoding is required ?
    User manual is really no help
  1. Replacing Car Battery Yourself
    By Hammer2001 in forum Alhambra
    Last Post: 01-03-2017, 09:10 PM
  2. Replacing AGM Battery
    By stuffandblah in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 13-06-2016, 06:16 PM
  3. Replacing Battery
    By 2fquick in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-12-2014, 09:43 AM
  4. Replacing BATTERY. In Q7
    By Q7quattro in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 28-02-2014, 09:03 PM
  5. replacing battery in key fob
    By dancerdave in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-01-2008, 10:51 PM
